3 members (DJC, TBM, sewin),
153
45
Topics49,838
Posts837,294
Posts: 537 Likes: 28
Posts: 537 Likes: 28 |
Thanks Lawrie.
Your photos take me several years back in time. In the 1980's I used to help in a Rallycross team. We converted a Talbot Sunbeam TI, a Triumph Dolomite Sprint (with a Rover 3.5 V8) and a Rover SD1 with 3.5 V8 engine. I think I still have some photos somewhere in my archive.
Dirk
1993 Morgan +4 (Connaught Green) 2009 Mini Cooper D 2024 Mercedes GLC 1994 Ford Motorhome
Posts: 2,361 |
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
Blimey! Exciting stuff. Do you cut the whole roof off in order to be able to fit a roll cage?
Posts: 2,361 |
Blimey! Exciting stuff. Do you cut the whole roof off in order to be able to fit a roll cage? It certainly does help but its not essential. The roof has been removed for 3 reason. Firstly the original had a sunroof, secondly the underside of roof had the sunroof mounting points which made it heavy and thirdly I have a non sun roof light skin to put back on. The windscreen surround was removed because it had a rust hole, as I can but new it made sense to fit a new one as we are at this stage.
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
Looks like a nice 105 GTV lurking in the background too..
99 plus 8 indigo
Posts: 2,361 |
Todays little update   The engine was then removed
Posts: 11,523 Likes: 312
Posts: 11,523 Likes: 312 |
I was expecting to see a bit more seam-welding or is that in the next stage ?
Posts: 2,361 |
I was expecting to see a bit more seam-welding or is that in the next stage ? I am long way off from starting the stitch welding process. The car is being fully stripped first, lightened where possible, then its off for a 3 stage dipping process. Then the build begins
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
The body looks in terrific nick for it’s age
Posts: 2,361 |
The body looks in terrific nick for it’s age I am amazed for a 34yr old car. She is very solid
