Morgan Aero 8
1 members (CraigL), 162 guests, and 47 robots.
John V6 63
My Goodwood Revival 2026
Clutch for a 1982 4/4
DVLA frustration.
Old Book
by Pundit - 21/09/26 01:39 PM
First Morgan as it is now
by Strathaven, September 15
Topics49,940
Posts838,603
#494970 21/01/18 02:17 PM
2 weeks ago I went to the Bicester event... and arrived with oil flowing over the front.
Fortunately...
- there was a shop open at the event which sold oil
- and a bendy filler funnel
- and I didn't drop the oil cap into the wing, in spite of the windchill taking the temperature below zero
And I set off homewards, gently.
About 12 miles into the trip, the engine cut out. In the outside lane of the A34, at 70.
Fortunately, there was space to get to the verge before the car lost momentum, and I found myself at the end of a slip road. So that worked out much better than it might have.
Williams kindly opened up on a Sunday afternoon to receive the car from the breakdown truck.
It turns out the trailing edge of the bumper had worn through the oil cooler. And when the engine came up to temperature, and the flow through the oil cooler started, oil pressure must've dropped/disappeared, and the ECO shut off everything to protect the engine.
So I'd recommend checking the clearance between your bumper's trailing edge & the oil cooler.
Will
Formerly Aero S5 #80
I trust this is covered by your warrenty.
Martin (Deano)
sorry to hear you had those issues Will - but ,boy; that could have been much, much worse.... scared
It doesn't bear thinking about what could have happened if the ECU hadn't shut the engine down ooo
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
le Asbo du Bling
le Asbo du Bling
That’s not good news.
Will in the picture is that oil you can see on the splitter just under the M of your number plate?
Slowly going green
Yes could have been much much worse, especially as MMC have no more engines.... sos
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
@asbojohn yes... and when I arrived it was streaking up between the grille & headlight
@deano yes, covered by warranty.
But not a peep out of Morgan (I rang the factory to make sure they knew what had happened, and to chase up the replacement part.) From any other manufacturer you might have expected anything from an acknowledgement to an apology.
@jamesBW well, I guess Morgan's warranty would have been replacing an engine!
Will
E
E
No there are no more engines for car production, it is reasonable to expect that either Morgan or BMW will have a few in stock to cover warranty work and replacements down the line.
there's some sort of EU requirement to keep parts in stock for 10 years - I imagine that extends to engines
Will
Hi Will, sorry to hear your news, that must have been a shock, it must have happened fairly close to Bicester given the rate of oil loss. How many miles have you covered now.
Hopefully all is fixed now, I guess the mountings have been modified to prevent reoccurrence.
Best wishes Ron
Good to hear all OK, but I was always taught if there's a leak don't drive to you know what/where etc.
