0 members (),
292
71
Topics49,870
Posts837,668
Posts: 60 |
I wish to replace my rocker switches on my 1980 Morgan plus 4 with the Lucas toggle switches . Do the original rocker switches operate with relays and do I need to install relays when replacing them with the new switches.
Posts: 12,260 Likes: 319
Posts: 12,260 Likes: 319 |
No relays are used with the original switches. If you are buying new Lucas toggle switches, be wary of the Chinese pattern stuff, when I did thins I found them to be rubbish and ended up using switches from the "Professional" range from Holdens.
Posts: 60 |
I cannot agree more as regards the quality of the Chinese versions. I was under the impression that I was buying a British product . I already have the new switches now , but when I went into the Holden sight their switches look very similar . Can you maybe advise the better product to consider getting new ones. Thanks
These are excellent:
https://www.holden.co.uk/displayProducts.asp?sg=1&pgCode=020&sgName=Electrical&pgName=Switches&agCode=0502&agName=Toggle+Switches+%2D+Professional
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
Holden
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 238 Likes: 3
Posts: 238 Likes: 3 |
https://www.maplin.co.uk/p/10a-toggle-switch-dpdt-momentary-on-off-on-n41krThese at Maplins are considerably cheaper, if you're concerned about the switches failing prematurely , the retain your relays , this will reduce the load on the switch contacts
1999 Morgan Plus 8. 3.9 .... 1961 Alvis TD21 Series1 3 Litre Auto....
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
- not used these myself, but the price for Lucas switches seems a lot cheaper than some others - https://www.merlinmotorsport.co.uk/p/lucas-toggle-switch-off-on-on-31788-ts-l31788Merlin are a good company to deal with in my experience too.... James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 60 |
Thanks for your suggestions
