6 members (RichardV6, sprinty, Tresco, Morganmike, MJF, yobtaf), 235 guests, and 76 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
#495363 24/01/18 09:48 AM
MOR404 Offline OP
I wish to replace my rocker switches on my 1980 Morgan plus 4 with the Lucas toggle switches . Do the original rocker switches operate with relays and do I need to install relays when replacing them with the new switches.
No relays are used with the original switches. If you are buying new Lucas toggle switches, be wary of the Chinese pattern stuff, when I did thins I found them to be rubbish and ended up using switches from the "Professional" range from Holdens.
MOR404 Offline OP
I cannot agree more as regards the quality of the Chinese versions. I was under the impression that I was buying a British product . I already have the new switches now , but when I went into the Holden sight their switches look very similar . Can you maybe advise the better product to consider getting new ones. Thanks
These are excellent:
https://www.holden.co.uk/displayProducts.asp?sg=1&pgCode=020&sgName=Electrical&pgName=Switches&agCode=0502&agName=Toggle+Switches+%2D+Professional
Holden
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
https://www.maplin.co.uk/p/10a-toggle-switch-dpdt-momentary-on-off-on-n41kr
These at Maplins are considerably cheaper, if you're concerned about the switches failing prematurely , the retain your relays , this will reduce the load on the switch contacts
1999 Morgan Plus 8. 3.9 ....
1961 Alvis TD21 Series1 3 Litre Auto....
- not used these myself, but the price for Lucas switches seems a lot cheaper than some others -
https://www.merlinmotorsport.co.uk/p/lucas-toggle-switch-off-on-on-31788-ts-l31788
Merlin are a good company to deal with in my experience too....
James
RR Evoque P300E Autobiography
Smart Brabus Convertible
Monkey Z125
MOR404 Offline OP
Thanks for your suggestions
