3 members (Graham, G4FUJ, RubyMog95, High Hamster), 356 guests, and 67 robots.
+8Rich 75
Topics49,861
Posts837,540
Jonny72
Page 1 of 5 1 2 3 4 5
#496151 28/01/18 12:24 PM
Hi guy's going along 50mph engine cut out complete no spluttering just stoped,would not start buy letting clutch out will still rolling along! stop turn off ing then away we go again. no probs carry on ,just as parking up stops again on tick over! turn ing off and on no fuel pump sound!off on again fuel pump sound car starts!!! happened to anybody else? Fuel pump or FP relay? sherlock
skullmog #496155 28/01/18 01:07 PM
My fuel pump died but it took a few last gasps for it to go. It wouldn't pump then it would but not for long. Something inside just gives up and it becomes deceased.
I don't know about England but it is very hard to find alcohol free benzine in the states and it has been pointed out elsewhere that alcohol will eat the seals in the pump leading to failure.
So with a new pump installed I search out alcohol free benzine wherever possible.
skullmog #496167 28/01/18 01:49 PM
Just wondering which pump is fitted to your respective models? I have converted my 1961 Plus 4 (TR3) to a Facet Cube low pressure electric fuel pump and ditched the standard mechanical pump. The Facet pumps are from the USA and I am hoping I have made the right choice. Do They suffer from seals breaking down?
Nev.
Nevbag #496173 28/01/18 02:29 PM
According to the parts manuals, there have been no changes with the fuel pump part number U280003 which, I believe, is a Range Rover or Land Rover origination.
Even this usage is a kludge in that one has to snip off the swing arm float that is the fuel gauge half of the pump before fitting. The fuel gauge is a separate entity.
skullmog #496178 28/01/18 02:47 PM
Cheers Michael cheers
skullmog #496192 28/01/18 04:15 PM
Your description sounds like my fuel pump failure. Engine quit dead, no pops, bangs or burbles. Had it trucked home. A new fuel pump fixed it.
Nevbag #496196 28/01/18 04:47 PM
Nev.
If your Facet Cube fuel pump is less than 10-15 years old it will have seals that can withstand the 10-15% ethylene fuel that most Americans are forced to use. But the material in these seals is fine for use with non-ethylene gasoline.
1961 +4 Four seater
"Crude, but effective."
skullmog #496215 28/01/18 07:10 PM
Thanks Guy's, but its a thee wheeler with fuel injection so pump in tank!!! wine
skullmog #496218 28/01/18 07:18 PM
The Facet is a great pump but I don't think Facet makes one that puts out 58 Psi, you need for fuel injection
hbatts #496238 28/01/18 08:58 PM
Just when you thinks all's well these little beasties will remind you who's boss.
If it's intermittent then hopefully it's just a dodgy earth or connector somewhere in the system.
Worth checking the intertial cutout as well - mine was forever tripping so is now cable tied shut.
Red Leader drive
