0 members (), 192 guests, and 72 robots.
+8Rich 76
Topics49,861
Posts837,542
Page 1 of 4 1 2 3 4
#500333 20/02/18 08:11 PM
IvorMog Offline OP
Had the MOT done today and all passed with flying colours and no advisories.
But we did spot a bit of end play in the front U Joint and I am getting some slight cluncks under certain conditions.
Nothing serious but it will need doing sooner of later.
So the question is how do you remove the prop-shaft so it can be dismantled to change the U Joint.
It disappears above the floor boards in the tunnel and emerges at the axle end.
At first glance it seems the floor boards would need to be removed but surely there's an easier way.
Anybody done it or can anyone point me to an old post which describes the job?
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Seats out, gearbox cover and propshaft tunnel out, undo the prop from the axle, slide it out the gearbox....
Almost sounds easy
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
On mine you can do this as above but not touching the interior....newer cars may of course be different.
IvorMog Offline OP
Almost sounds easy
Simon @ SiFab.co.uk
Oh Bu**er. Maybe I'll wait until I take the engine and gearbox or axle out.
Bob
2009 Black Roadster
Mine as well. Maybe worth taking a look at it?
1972 4/4 2 Seater
IvorMog Offline OP
I'm trying to understand what you and Richard are suggesting.
If you don't touch the interior how do you withdraw the shaft because the floor boards are below it?
Bob
2009 Black Roadster
There's a gap in the floorboards which gives access to the rear of the gearbox and the front u/j on the propshaft.
Later car, but it's like this.
1972 4/4 2 Seater
What Simon H has suggested is not difficult, it is just amatter of nuts and bolts. Had to do this when replacing the remote support rubbers on the gearbox.
1992 plus4 connaught green
IvorMog Offline OP
How easily do the leather gearbox and tunnel covers come off?
Are they glued on or do they just lift off?
Bob
2009 Black Roadster
The leather cover is usually held by lift the dots and duradots.
Page 1 of 4 1 2 3 4
