9 members (Zach, Julian BB, gmcn, JMcL, rory kim, Ian Wegg, Mats, Mr K, JohnHarris),
333
60
Topics49,859
Posts837,504
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
Had the MOT done today and all passed with flying colours and no advisories.
But we did spot a bit of end play in the front U Joint and I am getting some slight cluncks under certain conditions.
Nothing serious but it will need doing sooner of later.
So the question is how do you remove the prop-shaft so it can be dismantled to change the U Joint.
It disappears above the floor boards in the tunnel and emerges at the axle end.
At first glance it seems the floor boards would need to be removed but surely there's an easier way.
Anybody done it or can anyone point me to an old post which describes the job?
Bob
Posts: 1,415 |
Seats out, gearbox cover and propshaft tunnel out, undo the prop from the axle, slide it out the gearbox....
Almost sounds easy
Simon @ SiFab.co.uk
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
On mine you can do this as above but not touching the interior....newer cars may of course be different.
Richard 1976 4/4 4 Seater
Almost sounds easy
Simon @ SiFab.co.uk
Oh Bu**er. Maybe I'll wait until I take the engine and gearbox or axle out.
Bob
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
On mine you can do this as above but not touching the interior....newer cars may of course be different. Mine as well. Maybe worth taking a look at it?
1972 4/4 2 Seater
On mine you can do this as above but not touching the interior....newer cars may of course be different. Mine as well. Maybe worth taking a look at it? I'm trying to understand what you and Richard are suggesting. If you don't touch the interior how do you withdraw the shaft because the floor boards are below it?
Bob
On mine you can do this as above but not touching the interior....newer cars may of course be different. Mine as well. Maybe worth taking a look at it? I'm trying to understand what you and Richard are suggesting. If you don't touch the interior how do you withdraw the shaft because the floor boards are below it? There's a gap in the floorboards which gives access to the rear of the gearbox and the front u/j on the propshaft. Later car, but it's like this.
1972 4/4 2 Seater
Posts: 1,616 Likes: 1
Posts: 1,616 Likes: 1 |
What Simon H has suggested is not difficult, it is just amatter of nuts and bolts. Had to do this when replacing the remote support rubbers on the gearbox.
John 1992 plus4 connaught green
How easily do the leather gearbox and tunnel covers come off?
Are they glued on or do they just lift off?
Bob
Posts: 22,359 Likes: 353
Posts: 22,359 Likes: 353 |
The leather cover is usually held by lift the dots and duradots.
