8 members (brownbaker, nick w, GerardNL, Hamwich, MJF, High Hamster, Colin_Mackay, JohnHarris),
390
43
SORN
Topics48,376
Posts813,553
Members9,215
Posts: 28 |
whilest driving in rain one on my wipers came off - and before I switched them off the metal arm has made an "arc" scratch on the glass - any tips to polish out - its not very deep just annoying
Never seen in non green
Posts: 6,538 |
Try Meguairs Scratch Cover X or their less abrasive Polishing Compound.
But tread carefully!
Neil
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
I used a machine polisher to clean up my sidescreens. Not glass, I know, but most except deeper ones came clear. I used the Meguiars Scratch X and finished with fine paintwork polish. Glass is harder so a lot will depend on how deep your scratches are and how coarse an abrasive you use. Halfords sell a kit for glass polishing but I don’t know the details.
Posts: 526 Likes: 2
Posts: 526 Likes: 2 |
Try Autosol metal polish. I've used it quite a few times on different car windscreens and it works well (also good for getting scratches off watches)
Posts: 5,181 Likes: 2
Posts: 5,181 Likes: 2 |
try an optician, they have powders and paste for polishing glass.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
I used some glass cutting compound about 30 years ago on my BGT rear screen. I think it came from Frosts. The scratches were deep and it partially worked but the mandrel generated a lot of heat, distorted the glass and spattered the compound everywhere. If you can feel the scratch with your fingernail it will be an uphill struggle.
Posts: 11,610 Likes: 43
Posts: 11,610 Likes: 43 |
That’s exactly what I was going to post Do the fingernail test - if you can feel it, I would be resigned to it staying around If you can’t it should be polishable
Posts: 2,515 |
It should be covered on your insurance policy if it won't polish out.
1972 4/4 2 Seater
Posts: 7,914 Likes: 243
Posts: 7,914 Likes: 243 |
There are specialists who remove scratches from vandalised shop windows, so they must be mobile, might be worth a 'google'
Posts: 1,013 Likes: 31
Posts: 1,013 Likes: 31 |
Mark I have seen scratches polished out on a shop window and as Dave and Stewart have said if the scratch is deep then polishing it out will inevitably leave a distortion or wave in the glass. So really depends if the scratch is in your line of sight as a driver.
David Aero S4
