10 members (GrandadC, Biggle, mph, HawkMog, Grumpy2, Lordofthewings, ajg141, RichardV6, MartinB60, Moggo),
429
New
Topics48,365
Posts813,361
Members9,215
Posts: 1,238 Likes: 2
Posts: 1,238 Likes: 2 |
Peter - Autoglym produce a surface detailing clay bar kit which uses Autoglym Quick Detailer as a lubricant for the clay bar. The results are superb and you can literally feel the difference after minimal effort. Don.
Posts: 2,397 Likes: 14
Posts: 2,397 Likes: 14 |
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 909 Likes: 7
Posts: 909 Likes: 7 |
Whit degreaser from an bodyshop. Spray an cloth whith the degreaser an hang it with some tape over the place with the problem. Keep it wet 5 min an you can remover the tar without scratching or polishing .You can find the degreaser in an shop where they sell carpaint . It is used before painting an is total neutral for the paintwork.
Stefan
Posts: 764 Likes: 8
Posts: 764 Likes: 8 |
While WD40 will remove tar spots, it is a lubricant not a solvent so it should leave a film of oil behind if its doing its job, its probably an insignificant amount and you really may well buff it off but if you spilled an oil based paint on your shirt you would not use WD40 to clean it off as it would leave a oily stain. A degreaser is the right product to use whether its cheap white sprit/turpentine or costly tin made to do the same job but anything that removes tar will also remove wax. John k
1993 T16 +4 Lancia Blue.
Posts: 970 |
Wd40 ( it's just fish oil ) I've been using it for 40 plus yrs. Petrol on a cloth works just as well
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 5,366 Likes: 15
Posts: 5,366 Likes: 15 |
White spirit then re -wax? +1 in my experience.
Posts: 112 |
No mention of clay bars yet. Are tar spots too much for them?
I've used the 'white spirit then wax immediately' method many times. Relatively simple and seems to be effective.
Posts: 1,578 Likes: 105
Posts: 1,578 Likes: 105 |
Piece of 80 grit paper and half a pint of battery acid usually does the trick for me....
Arwyn
Posts: 11,868 Likes: 138
Posts: 11,868 Likes: 138 |
Arwyn Nah, you want to chisel them off mate. 2lb lump hammer, ½" cold chisel. One whack and they're gone. Easy.
Posts: 26,761 Likes: 425
Posts: 26,761 Likes: 425 |
