5 members (piquet, GrumpyPa, JMcL, DavidR, vincentvg), 296 guests, and 45 robots.
Luddite 50
Posts837,951
Page 2 of 4 1 2 3 4
Peter - Autoglym produce a surface detailing clay bar kit which uses Autoglym Quick Detailer as a lubricant for the clay bar. The results are superb and you can literally feel the difference after minimal effort.
Don.
+1 for petrol.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Whit degreaser from an bodyshop. Spray an cloth whith the degreaser an hang it with some tape over the place with the problem. Keep it wet 5 min an you can remover the tar without scratching or polishing .You can find the degreaser in an shop where they sell carpaint . It is used before painting an is total neutral for the paintwork.
Stefan
jbk Offline
While WD40 will remove tar spots, it is a lubricant not a solvent so it should leave a film of oil behind if its doing its job, its probably an insignificant amount and you really may well buff it off but if you spilled an oil based paint on your shirt you would not use WD40 to clean it off as it would leave a oily stain.
A degreaser is the right product to use whether its cheap white sprit/turpentine or costly tin made to do the same job but anything that removes tar will also remove wax.
John k
1993 T16 +4 Lancia Blue.
Wd40 ( it's just fish oil ) I've been using it for 40 plus yrs. Petrol on a cloth works just as well
Magwa
1950 Allis Chalmers B tractor
2000 Porsche boxster
2014 Skoda yeti 4x4 elegans
Originally Posted By jbk
White spirit then re -wax?
+1 in my experience.
Reg
No mention of clay bars yet. Are tar spots too much for them?
I've used the 'white spirit then wax immediately' method many times. Relatively simple and seems to be effective.
Piece of 80 grit paper and half a pint of battery acid usually does the trick for me....
Arwyn
Arwyn
Nah, you want to chisel them off mate. 2lb lump hammer, ½" cold chisel. One whack and they're gone. Easy.
Blowtorch anyone?
Page 2 of 4 1 2 3 4
