9 members (PaulJ, John V6, MATTMOG, DCH, 1560, BobtheTrain, sprinty, Mr Mogoo, gomog),
323
47
Posts837,971
Posts: 1,245 Likes: 2
Posts: 1,245 Likes: 2 |
Peter - Autoglym produce a surface detailing clay bar kit which uses Autoglym Quick Detailer as a lubricant for the clay bar. The results are superb and you can literally feel the difference after minimal effort. Don.
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 934 Likes: 12
Posts: 934 Likes: 12 |
Whit degreaser from an bodyshop. Spray an cloth whith the degreaser an hang it with some tape over the place with the problem. Keep it wet 5 min an you can remover the tar without scratching or polishing .You can find the degreaser in an shop where they sell carpaint . It is used before painting an is total neutral for the paintwork.
Stefan
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
While WD40 will remove tar spots, it is a lubricant not a solvent so it should leave a film of oil behind if its doing its job, its probably an insignificant amount and you really may well buff it off but if you spilled an oil based paint on your shirt you would not use WD40 to clean it off as it would leave a oily stain. A degreaser is the right product to use whether its cheap white sprit/turpentine or costly tin made to do the same job but anything that removes tar will also remove wax. John k
1993 T16 +4 Lancia Blue.
Posts: 970 Likes: 1
Posts: 970 Likes: 1 |
Wd40 ( it's just fish oil ) I've been using it for 40 plus yrs. Petrol on a cloth works just as well
Magwa 1950 Allis Chalmers B tractor 2000 Porsche boxster 2014 Skoda yeti 4x4 elegans
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
White spirit then re -wax? +1 in my experience.
Posts: 112 |
No mention of clay bars yet. Are tar spots too much for them?
I've used the 'white spirit then wax immediately' method many times. Relatively simple and seems to be effective.
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
Piece of 80 grit paper and half a pint of battery acid usually does the trick for me....
Arwyn
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
Arwyn Nah, you want to chisel them off mate. 2lb lump hammer, ½" cold chisel. One whack and they're gone. Easy.
Posts: 27,834 Likes: 758
Posts: 27,834 Likes: 758 |
