11 members (Mr K, JohnHarris, Mats, Julian BB, Biggle, JMcL, Sir Percival, mph, Bitsobrits, John Winn, Burgundymog),
399
33
Topics49,859
Posts837,504
Posts: 146 Likes: 3
It took 37 Years! L - Learner Plates On
Posts: 146 Likes: 3 |
My 1972 4/4 1600 was at BHM today for a service and MOT. They discovered a "pinhole" leak from the top radiator outlet to the header tank which I'm told can be repaired by soldering. Borough Green is a long way from home and I assume that radiator soldering is not a specialist Morgan task so wondered whether I could get it done more locally.
I'd be grateful for any recommendations for such work in the Hampshire/West Sussex area, please.
Many thanks
Mark
Posts: 22,359 Likes: 353
Posts: 22,359 Likes: 353 |
Not sure if Serck Services still trade but they were a national radiator supplier and repairer.
Posts: 1,616 Likes: 142
Posts: 1,616 Likes: 142 |
Yellow Pages job or may be a friendly plumber
If the pinhole is not too bad you could also consider a dab of epoxy resin but others might consider that a bodge
Arwyn
Posts: 1,616 Likes: 1 |
Why not use Holts radweld.
John 1992 plus4 connaught green
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Any radiator repairer can do that job - there is nothing special about a Morgan radiator.
FWIW I have a heat exchanger on my boat - it is in effect a radiator but instead of air flowing through it, it has sea water. Before I bought the boat in 2009 the owner had bodged a repair of the stack of tubes in the heat exchanger by using epoxy resin. To my surprise, that reapir still hold water and pressure tight today. Seems to be every bit as good as solder.
Its not a bodge if it works....
Arwyn
Posts: 146 Likes: 3
FWIW I have a heat exchanger on my boat - it is in effect a radiator but instead of air flowing through it, it has sea water. Before I bought the boat in 2009 the owner had bodged a repair of the stack of tubes in the heat exchanger by using epoxy resin. To my surprise, that reapir still hold water and pressure tight today. Seems to be every bit as good as solder. Perhaps I should go onto the PBO forum and ask which expoxy I should use - that would elicit more answers than there are choices of expoxy!
Posts: 146 Likes: 3
Arwyn I’ve always wondered what my motto should be when I get my peerage. All I need t do now is figure out how to incorporate home cured bacon, home made sausage and bread, my boat and my Morgan into a heraldic shield and await the call!
JB Weld will fix that easily.
The proper description of a bodge is "Temporary Repair".
I once congratulated an RAC man on a fantastic bodge when my friends County 90 lost the power feed to the diesel fuel pump. The cable had chafed under the transmission tunnel in an inaccessible place.
"That's not a bodge" he said, clearly defensive, "It's a temporary repair".
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
"That's not a bodge" he said, clearly defensive, "It's a temporary repair". Only a bodge when it fails.
Richard 1976 4/4 4 Seater
