3 members (Ritchie B, TBM, BHV),
266
84
Topics49,867
Posts837,615
Posts: 11,531 Likes: 316
Posts: 11,531 Likes: 316 |
Will look them out in the morning and DM you,
Posts: 7,363 |
Does that really help Neil or do you just turn the warning light off? P.S. Like others, I love the Goodwood photo
Brian
1970 Morgan Plus 8 - Moss Box (Indigo Blue) 2014 Morgan SP1 (Rocket Red) 2015 Morgan Plus 8 (Rocket Blue)
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
I have turned the warning light off on the assumption that it is one of the pipes around the fuel tank/pump/emissions canister that has come lose. I am told that at start up the fuel pump over pressurises the system to check for leaks....
Bosch ECMs identify the electrical function of the pump as DM-TL.
+8 4.8
Posts: 1,508 Likes: 57
Posts: 1,508 Likes: 57 |
Surprisingly, the only error I have is this:
I think that error could be seen as normal in a Morgan! My fuel gauge wanders around like a fiddler's elbow, even when sitting perfectly still.
+8 4.8
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
With generic type readers try to get ones that are actually compatible with the ECU you are reading otherwise what is reported can lead to confusion.
Morgan ECU I think it's readable only after a few beers
I have finally got the other reader back from my old colleague so if you still need one I have it here.
Posts: 638 |
Where is the OBD plus on a S4 located? Thanks
Michael
Aero 8 S4
I believe it needs to be near the same point on all cars by law. Under the steering wheel side of the dash nearer to the outside of the car. On mine it is tucked up under the bottom of the dash. https://www.aero-racing.co.uk/partsbooks/supersports/steerwheel&dash.htmPart 16 I think. Do you need the reader as I finally got it back.
