Morgan Aero 8
5 members (lez, sewin, High Hamster, RichardV6, Martin W), 243 guests, and 58 robots.
+8Rich 76
Topics49,859
Posts837,513
Jonny72
Page 3 of 3 1 2 3
Neilda #509993 23/04/18 07:35 PM
Smile, it confuses them
Originally Posted By Neilda
Hi - yes, please do let me know.... I have ordered a 3rd scanner which arrives today:
https://www.amazon.co.uk/gp/product/B011KSTC6I/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
This is supposed to work with BMW's - so will report back.
Will look them out in the morning and DM you,
Ale_72 #510004 23/04/18 08:43 PM
Originally Posted By Ale_72
By switching off the brain and reading here...
http://www.bimmerfest.com/forums/showthread.php?t=432282
2FA3 HO-proc.failure, coding missing
2A14 DM-TL Fine leak
2A15 tank-ventilation-system major leak
2A17 DM-TL module
Does that really help Neil or do you just turn the warning light off?
P.S. Like others, I love the Goodwood photo flag
Brian
2014 Morgan SP1 (Rocket Red)
Neilda #510067 24/04/18 09:21 AM
Neilda Offline OP
I have turned the warning light off on the assumption that it is one of the pipes around the fuel tank/pump/emissions canister that has come lose. I am told that at start up the fuel pump over pressurises the system to check for leaks....
Bosch ECMs identify the electrical function of the pump as DM-TL.
+8 4.8
Neilda #510655 28/04/18 07:36 AM
Surprisingly, the only error I have is this:
Neilda #510691 28/04/18 01:16 PM
Neilda Offline OP
I think that error could be seen as normal in a Morgan! My fuel gauge wanders around like a fiddler's elbow, even when sitting perfectly still.
+8 4.8
Neilda #510764 29/04/18 09:37 AM
With generic type readers try to get ones that are actually compatible with the ECU you are reading otherwise what is reported can lead to confusion.
Mark - No Longer driving
Neilda #510768 29/04/18 09:48 AM
Morgan ECU I think it's readable only after a few beers laugh
Neilda #512391 09/05/18 11:10 AM
I have finally got the other reader back from my old colleague so if you still need one I have it here.
Neilda #515016 29/05/18 10:44 AM
Where is the OBD plus on a S4 located?
Thanks
Michael
Aero 8 S4
Neilda #515045 29/05/18 11:54 AM
I believe it needs to be near the same point on all cars by law. Under the steering wheel side of the dash nearer to the outside of the car. On mine it is tucked up under the bottom of the dash.
https://www.aero-racing.co.uk/partsbooks/supersports/steerwheel&dash.htm
Part 16 I think.
Do you need the reader as I finally got it back.
Page 3 of 3 1 2 3
