Topics48,349
Posts813,091
Members9,212
Posts: 120 |
Hi Dab, not sure. The dealer told me their electrician said it was a box that sent the current to the left side indicators and that it wasn't allowing enough current through. The box was to be reordered and was simply "plug and play". The module description was Morgans own description.
A friend has suggested it may well be a transistor in the black box that's at fault and that it ought to be fixable. That is of course just his surmising after our phone conversation.
Apologies, but electrics are a complete mystery to me. Does this sound like the flasher relay to you?
Posts: 20 |
I had a problem with the full beam which could not be switched on. The dealer thought it was a wiring problem but could not find the fault. They tried a new indicator assembly but the fault was still there
On my way to the MTWC opening run the hazard warning lights came on, all the lights on the dashbord lit up and when I tried to switch off the engine it kept running with the key out of the ignition!
The M3W was driven to the hotel where the only way to stop the engine was to stall it and after that it would not start
Skullmog spent over 2 hours on the Saturday evening trying to find the problem and after ruling out fuses, relays, immobiliser and ECU he thought it was the cambus. Thanks again Kevin for your help
The vehicle was trailered back to the dealer and 4.5 weeks later was fixed, the problem being the indicator module unit. On the invoice it was shown as M3W TURN SIGNAL HEADLAMP MODULE and was £39.89 plus VAT
The old part was given to Skullmog for him to look at
At the time we, the MTWC, did not know of anyone else having a problem with this unit
Gerald
Posts: 2,141 Likes: 43
Posts: 2,141 Likes: 43 |
The part is an Indicator Module and is Morgan Part E340098. As mentioned, Skullmog is trying to identify what the part is as all the non Morgan identification has been removed. It lives under the ECU and is not easy to get at. It seems to be a likely cause of any "haunted lights" problems, although there are only two cases we know of at the moment.
Posts: 120 |
Thanks guys. Looks like we're on the right track. Just hope Skullmog can crack the identity because I suspect this could be another issue on the cusp of causing an increasing number of headaches.
The phrase, "we're waiting for stock" sends chills down my spine when it originates from Morgan.
Posts: 1,673 Likes: 25
Posts: 1,673 Likes: 25 |
I wonder if it's by the same manufacturer that makes the ECU?
Andy
Posts: 22 |
There’s some pretty scary reading here! 😳
2017 MTW Graphite Blue
Posts: 1,789 Likes: 3
Posts: 1,789 Likes: 3 |
Case No.3
Last year if I turned my hazard warning lights on the fuel pump would run and the engine could be started and would stay running as long as the hazard lights were on.
Turning the hazard lights off also stopped the engine.
All without keys!
It has rectified itself, shame it didn't self heal other past problems.
One for Scullmog now, what is the black plastic box full of relays for under the fuse box?
Posts: 1,544 |
Investigating box! it has 2 relays and 3 micro chips +other diode and resistors ! made by Electromech number EA0021i4 (not found on Google yet) Im scanning the wiring diagram to find out which of the feeds for the fuse box and other components go through this box and if they can be moved to a separate control relay..
Posts: 120 |
Great work skullmog. There are a number of Electromechs out there but one based in Ramsgate is a PCB specialist. I wonder if they're our supplier?
Posts: 7,926 Likes: 217
Posts: 7,926 Likes: 217 |
I had an associated issue with my M3W which seems to have cured itself. The hazard warning lights would come on uncommanded. Turning the hazard switch on then off fixed the issue which happened on at least three occasions during first few months of owning this 2016 car.
When others mention similar faults involving running of engine, fuel pump etc., it leads me to believe the functioning of the TSM headlight/flasher unit is heavily integrated with the ECU!
FWIW the flasher unit is fed by fuse 10 (5amp) green wire. Colour codes seem to follow normal convention with fused feed green, L/H indicators green/white and R/H green/red.
