7 members (Image, +8Rich, JMcL, Guten, Chris Cosher, Ian Wegg, Deejay),
350
65
Topics49,850
Posts837,433
Posts: 2,822 Likes: 155
Posts: 2,822 Likes: 155 |
Rear tyre is just a 175/65 R15, doesn't need anything fancy, the original Yokohama Bu-Earth is a good tyre and works well, some of us over here are using cross-climate tyres but cold weather isn't likely to be a big issue for you! Pretty much anything that isn't too asymmetric will do the job, it's the front tyres that limit the grip as a rule. Best/latest/easiest rear wheel alignment I've come up with is to get the wheel slightly forward of where it wants to be (belt a bit over slack) with the spindle hand tight giving a bit of resistance to adjustment, then draw one side back till it is same gap each side from the forward edge of the outer adjustment plate to the middle of the cut away in the swing arm. I use a caliper for this and just compare the two sides till they are the same - the measurement doesn't matter. Then draw back evenly on both adjusters till the belt is tight; about a 45 degree twist in the middle of the lower run with weight on the wheel then nip up the spindle solidly. Quick and rough sketch;  I did a fair bit of measuring on my swingarm to convince myself that this gets the spindle square across the back and parallel to the axis of the swingarm bearings and it seems to work.
Posts: 2,221 Likes: 181
Posts: 2,221 Likes: 181 |
Definitely need the cooling kit and I would recommend getting an oil and bevel box cooler kit. Your temperatures are similar to our desert conditions, the oil gets too hot and this degrades the oil and you loose 30% of engine performance. Kits can be found at: www.morgancustom.net
Posts: 237 |
That transparent timing case looks awesome. One of the local morgan owners has one on his.
he is by the way touring europe with it
Piloting Saint Ex the Morgan
Posts: 37,414 Likes: 977
Posts: 37,414 Likes: 977 |
Posts: 237 |
You can find him on instagram under the name of osama_alkhashram. Mirror finish 3 wheeler.
Thanks - I don't do that phone stuff, is he on here (Osama) or facebook I wonder ?
I asked about Q8 as I seem to recall him talking about a European trip this year.
Posts: 237 |
I think it might be the same person since i think he is native from Kuwait but i cannot confirm it.
In any case I haven't heard from mr big shot yet so no morgan for me still :-(
Posts: 7,342 Likes: 49
Posts: 7,342 Likes: 49 |
Any luck with the M3W purchase? I think it might be the same person since i think he is native from Kuwait but i cannot confirm it.
I hope you hear from him soon and can close the deal..
Posts: 237 |
Still not in the country so nothing is closed as of yet. You'll be the first to know when its done.
Patience is key here
