4 members (+8Rich, Burgundymog, Zach, Davetherave), 382 guests, and 89 robots.
Topics49,851
Posts837,441
Page 6 of 7 1 2 3 4 5 6 7
Rear tyre is just a 175/65 R15, doesn't need anything fancy, the original Yokohama Bu-Earth is a good tyre and works well, some of us over here are using cross-climate tyres but cold weather isn't likely to be a big issue for you! Pretty much anything that isn't too asymmetric will do the job, it's the front tyres that limit the grip as a rule.
Best/latest/easiest rear wheel alignment I've come up with is to get the wheel slightly forward of where it wants to be (belt a bit over slack) with the spindle hand tight giving a bit of resistance to adjustment, then draw one side back till it is same gap each side from the forward edge of the outer adjustment plate to the middle of the cut away in the swing arm. I use a caliper for this and just compare the two sides till they are the same - the measurement doesn't matter. Then draw back evenly on both adjusters till the belt is tight; about a 45 degree twist in the middle of the lower run with weight on the wheel then nip up the spindle solidly.
Quick and rough sketch;
I did a fair bit of measuring on my swingarm to convince myself that this gets the spindle square across the back and parallel to the axis of the swingarm bearings and it seems to work.
Definitely need the cooling kit and I would recommend getting an oil and bevel box cooler kit. Your temperatures are similar to our desert conditions, the oil gets too hot and this degrades the oil and you loose 30% of engine performance. Kits can be found at: www.morgancustom.net
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
osten Offline OP
That transparent timing case looks awesome. One of the local morgan owners has one on his.
he is by the way touring europe with it
Piloting Saint Ex the Morgan
Is that Q8 ?
osten Offline OP
You can find him on instagram under the name of osama_alkhashram. Mirror finish 3 wheeler.
Thanks - I don't do that phone stuff, is he on here (Osama) or facebook I wonder ?
I asked about Q8 as I seem to recall him talking about a European trip this year.
osten Offline OP
I think it might be the same person since i think he is native from Kuwait but i cannot confirm it.
In any case I haven't heard from mr big shot yet so no morgan for me still :-(
Any luck with the M3W purchase?
I hope you hear from him soon and can close the deal..
osten Offline OP
Still not in the country so nothing is closed as of yet. You'll be the first to know when its done.
Patience is key here
