10 members (CooperMan, OZ 4/4, DaveK, Joe Speetjens, CraigL, IcePack, Mick Annick, Mogdavid, Topline123, Morganmike),
306
SORN
New
Topics48,368
Posts813,416
Members9,215
Posts: 91 |
Hi there, having a clear out and I have a pair of Armstrong Type Lever Suspension Dampers as removed a while ago from my 1981 +8 when I upgraded to a different rear set up. Are these still of any value / use to anyone ? Got the steel mounting plates as well. Thanks Steve.
Posts: 35,796 Likes: 474
Posts: 35,796 Likes: 474 |
I would have thought some of the purist rebuilders could be interested. Worth a fleabay maybe.
OXR 5 L - Learner Plates On
Posts: 209 |
Posts: 1,943 |
My experience and testing tell Me the Armstrong Levers are as good as the Koni's. Unless the levers leak, keep them just in case.
Button
Posts: 898 |
Would you store them next to the grinding paste or the fuse wire for the consumer unit ( house switchboard ) that was changed out 25 years ago.
Posts: 21,871 Likes: 168
Posts: 21,871 Likes: 168 |
Very good. Although the master switch in my garage still has three proper fuses with real fuse wire. I rediscovered that when fitting my led strip lights and not reading the instructions......
So then I had to dig out the fuse wire - wrapped around a piece of branded cardboard........
Talking of disused tools......feeler gauges. Haven't used them for over ten years......
Posts: 11,870 Likes: 138
Posts: 11,870 Likes: 138 |
I've still got wire fuses in the isolation switches to a couple of my sheds, and I'm hoping they don't blow anytime as I don't have any spare fuse wire.
Fortunately not likely as I have mcbs back at the main distribution board which are much more sensitive, but if any of you guys come across any spare fuse wire I'll gladly provide a home for it!
If you get really desperate Tim I can send you a short length through the post!
If you get really desperate Tim I can send you a short length through the post! Thanks Dave, but I should be ok, the mcbs trip far faster than the wire fuses melt. It's time I got round to rewiring those sections anyway, it's all a bit Heath Robinson with 30A cable strung along catenary wires across the garden. I really ought to put in some proper SWA or something.
The funny thing was that when I (ahem) mismanaged my new lights, it tripped the main board but also blew the fuse............
I should have known better........
