I purchased one at Blenheim from BHM. Excellent quality as you would expect from Cain!
It should have been a half hour job, but you know how these things pan out...........................
Nice etched logo which I have fitted facing forward, and it comes with two allen headed countersunk machine screws and a drill bit........
What could possibly go wrong.
I don't have a G clamp small enough to hold the piece, but cable ties are good enough!
Get it level!!
Obviously the Morgan needs lifting quite a way. Even so I had to take some covers off the pit to get the drill in position.
The cross-member is thick and so takes time to drill through. If you wish to protect the gearbox casing, insert either a piece of wood, or metal above the cross-member to take the force out of the drill as it comes through.
On the second hole, just at the point of penetration, the bit stuck, and the end broke off...... Not a disaster as I have other drills, but access was tight, and my affliction of positional vertigo makes it quite hard to move about under the Morgan without the world spinning.................
Then more trouble loomed. I dropped one of the machine screws into the pit, and it did one of those trans-dimensional shifts. It vanished......... Half an hour later and losing patience I had to give up. It had gone................
A quick message to the Cain-meister, and a replacement was in the post.........
So today I finished the half hour job........
The quality is superb. Yes I could have made one, but it wouldn't have been as good as this.
I probably won't fit one to my Roadster because the sump is much lower than this, but a worthwhile addition for 4/4 and Plus 4.
