3 members (JMcL, TBM, SCX358G),
78
34
Old Book
Topics49,940
Posts838,611
Posts: 365 |
Just curious if anyone threaded their shifter rod. My shifter rod/knob is not threaded and has some funny little adapter. I have looked around but very limited options for shifter knobs without threads. If I can thread the rod to a miata thread pattern 10-1.25 there is a lot of awesome options (i.e., voodoo) knobs that might be a little closer to matching the emergency brake knob as well.
What looks like a challenge off the bat is that the shifter rod diameter is about 10.9MM so I suspect to thread to 10mm the shifter rod needs to be turned down and then threaded.
Appreciate any thoughts.
Ken
2017 M3W Sport Green
Posts: 807 Likes: 38
Posts: 807 Likes: 38 |
Interesting. My late 2012 machine has a threaded shifter. It might be just as easier to source a new or used Miata shifter?
Steve Late 2012 M3W
Posts: 365 |
Might be a winter project and buy a Miata short shifter kit. I know some of the Miata guys rave about the short shifter and certain guys will even custom bend it for you.
Posts: 557 |
I bought a “touring” knob from the Morgan’s website. It’s a nice polished-aluminum knob. Then I used my buffing wheel and removed the anodizing from the e-brake knob - looks really cool and matches the shifter. https://www.morgan-motor.co.uk/mmc/shop/index.php/polished-aluminium-gear-knob.html
Posts: 365 |
Thanks Kankel that is a ry ce option. I gave up looking and as a former multiple miata guy I broke down as I could no longer live without a voodoo knob on the miata trans. The good news is I found the guy that custom engraved the voodoo knobs Joe and I am putting the morgan logo on it. The knob is threaded so will spend the bucks on a short shifter. Another miata special as the guy is willing to make a custom length and bend short throw shifter. .
Spendy but only money.
Thinking of adding 1-2 inches to the shifter so the shifter clears everything a bit better.
Posts: 321 |
Might be a winter project and buy a Miata short shifter kit. I know some of the Miata guys rave about the short shifter and certain guys will even custom bend it for you. Which guys? I recently posted a thread about my desire to reduce the length of my gear shifter on my 2016 Roadster as I find it sits too high and would benefit from being about an inch shorter, even though I understand this will make the throw a bit stiffer. However, in doing so I will have to have the shaft re threaded.
3.7 Roadster Porsche 964 C2 JCW Mini Cooper S Cab BMW F750GS +4 4 1995-2002 / LM 62 +8 2002-07
Posts: 365 |
Miata roadster is willing to do a custom bend and length. By the way if you buy the short throw you can get away with a longer shaft. http://miataroadster.com
Posts: 25 |
2Sharp, would you be willing to share the person doing the voodoo shift knob? I'd go for one myself. Aluminum? Delrin? Brass? Brass I think could be neat with the weight of it.
Posts: 365 |
http://www.knobmeister.comI would email joe directly. If you want a picture i can send you my new knob. Joe engraved the morgan logo on mine but in the past he has done the shift pattern for me. Voodoo knobs are awesome.
Posts: 1,947 |
I'm considering a knob with a 7 speed shift pattern engraved.
