7 members (DJC, tommog, Tweed19er, dogmog, RichardV6, James B W, OZ 4/4),
269
36
Topics48,345
Posts813,047
Posts: 15,794 Likes: 14
Posts: 15,794 Likes: 14 |
Tarka's power steering pump reservoir is a bit low. The hand book says that MMC use 33g automatic transmission fluid.
The full specification is Ford M2C-33g. This Ford ATF fluid is red.
My fluid is a dirty green colour, BMW ATF fluid is green.
Would other Aero Owners know if their fluid is red or green, and if it is green it suggests that contrary to the handbook, MMC has used the same ATF Fluid for the transmission and power steering.
Advice much appreciated!!
Posts: 5,108 Likes: 56
Black Rat Charter Member
Posts: 5,108 Likes: 56 |
Advice much appreciated!! My power steering is electric, no fluid.
Posts: 1,959 Likes: 15
Posts: 1,959 Likes: 15 |
Mine is Green, I just stuck my finger in there to double check.
Posts: 5,181 Likes: 2
Posts: 5,181 Likes: 2 |
Mine is Green, I just stuck my finger in there to double check. . Ughh.
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
Mine is Green, I just stuck my finger in there to double check. . Ughh. Essex lad.....what do you expect! Stick their fingers anywhere!
Posts: 5,880 Likes: 20
Posts: 5,880 Likes: 20 |
Bet he didnt drop his bag of chips!
I very much doubt that there would be any real difference in performance Peter. But there is a risk that one is natural and the other is synthetic, like with brake fluid, so probably best to use the BMW stuff.
Posts: 2,515 |
I'd be more worried about why it's losing fluid than the colour of it.
1972 4/4 2 Seater
I'd be more worried about why it's losing fluid than the colour of it. I am also concerned, not just by the loss but also because the fluid is dirty, not clear green. I fear expensive repairs may be on the horizon. I'll top it up and check regularly. If it continues to lose fluid I'll ask Williams to investigate at the annual service in October.
Posts: 3,547 Likes: 4
Posts: 3,547 Likes: 4 |
What is the service schedule frequency, do yo have any service sheets indicating that it was done?
Posts: 7,895 Likes: 241
Posts: 7,895 Likes: 241 |
On normal tintops power steering fluid is not changed at service intervals (no provision to drain it) it's just down as a 'top up as required'
So if the level is dropping the system needs checking for leaks, it's sometimes just a tiny weep on a pipe joint
