2 members (TeddyAds, vincentvg), 183 guests, and 85 robots.
Topics49,848
Posts837,396
DazMog, The Impaler, tlchzj79
#530632 29/08/18 04:48 PM
E
E
Is there a wiring diagram for a newer Morgan 2018 Plus 4 /Roadster or one that's similar
thanks...
Hi, probably here at the end of the part guide for your model
https://mogparts.net/parts-guide
Dada,
Plus Six "Samantha" (the wooden witch)
Ed,
they don't do wiring diagrams now only loom diagrams which are like chocolate tea pots
http://www.gomog.com/allmorgan/roadster.htm
John V6 #530791 30/08/18 04:08 PM
Originally Posted By John V6
Ed,
I couldn't agree more. Here a splice, there a splice, everywhere a splice.
Best Regards
Lang may yer lum reek
John V6 #530874 30/08/18 10:49 PM
Ed,
Nevertheless you can learn a lot from the loom diagrams if you have the patience to decode the cable colour abbreviations, since individual cable runs are usually numbered as well.
In version 6.0 of the 2014 on classic parts manual (seemingly the current one) I notice that as well as loom diagrams there are several conventional ones, for the Roadster at least. Each drawing deals with a single aspect of the electrics - headlights, reversing and fog lights, heater controls etc. as well as a range of engine ones including solenoids for the variable cam timing. This simplifies cable tracing enormously.
Patience is a big plus when decoding/tracing wiring on a Morgan!
I print off a copy and use coloured highlighters to trace the wires I need to follow then compare them with what is actually on the car! idea
I keep them afterwards in case needed again (with notes added on).
For my Plus8 the Gomog file splits the wiring into 3 parts....
front/engine
Dash
Rear.
