3 members (RichardV6, Zach, Themorganeer), 193 guests, and 54 robots.
Topics49,846
Posts837,382
Page 1 of 9 1 2 3 4 5 6 7 8 9
The switch does not latch in and the fog light does not go on. Does anyone know if these can be repaired and if not where can I get a new switch. Melvyn Rutter cannot help.
Thanks
Just unbolt the foig lights and tape off the wires. Remove the switch and then get an MoT . Next you need a decent MoT station who looks after safety but doesnt do stupid things like this one did.
What switch type is it? what model of Mog is it.
Oooops just seen it - doh
Mark - No Longer driving
It’s an integrated rear fog light so I can’t take it off. The switch is round, illuminated and the car is a 1600cc 2014 4/4. To turn on foglight you press it and press again to turn it off.
Your 'Latching relay' is faulty, should be located in the engine compartment fuse box
It works when the headlamps are on - on later cars.
The switch should stay in when pressed like the others even when no power is supplied so I don’t know where a latching relay comes into it. When the headlights are on the fog light does not work..
Can you post a photo of your switch type ?
I will when I can find out how!
Hi Jon
It’s the same as this one:
https://goo.gl/images/XUdVTq
