6 members (sprinty, Soleng, piquet, Vansrv6, Graham, G4FUJ, Sir Percival),
180
45
Topics49,843
Posts837,340
Posts: 99 |
The switch does not latch in and the fog light does not go on. Does anyone know if these can be repaired and if not where can I get a new switch. Melvyn Rutter cannot help. Thanks
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Just unbolt the foig lights and tape off the wires. Remove the switch and then get an MoT . Next you need a decent MoT station who looks after safety but doesnt do stupid things like this one did.
Posts: 3,550 Likes: 5
Posts: 3,550 Likes: 5 |
What switch type is it? what model of Mog is it.
Oooops just seen it - doh
Posts: 99 |
It’s an integrated rear fog light so I can’t take it off. The switch is round, illuminated and the car is a 1600cc 2014 4/4. To turn on foglight you press it and press again to turn it off.
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
Your 'Latching relay' is faulty, should be located in the engine compartment fuse box
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
It works when the headlamps are on - on later cars.
Posts: 99 |
The switch should stay in when pressed like the others even when no power is supplied so I don’t know where a latching relay comes into it. When the headlights are on the fog light does not work..
Can you post a photo of your switch type ?
Posts: 99 |
I will when I can find out how!
Posts: 99 |
Hi Jon It’s the same as this one: https://goo.gl/images/XUdVTq
