6 members (+8Rich, Morganmike, High Hamster, deano, RichardV6, Bobajobbob), 243 guests, and 89 robots.
+8Rich 78
Topics49,872
Posts837,704
Rudolf
Page 1 of 4 1 2 3 4
#53834 06/12/10 10:43 AM
le Asbo du Bling
le Asbo du Bling
As the title states.
Morgan 3 Wheeler Site smile
Slowly going green
asbojohn #53836 06/12/10 11:00 AM
like it.
interesting the way it is being marketed 'e.g. the big build up'
A11OGE #53845 06/12/10 01:06 PM
All pictures show a left-hand drive car. Interesting.
Andreas
+4
109er #53846 06/12/10 01:25 PM
I believe the main market for the 3 wheeler is expected to be the USA, hence HD engine + left hand drive etc. Mind you there has been great interest in the UK. uk
A11OGE #53858 06/12/10 06:09 PM
the output shaft is left hand/ rear of the engine when fitted to a motorcycle, turn the engine through ninety degrees and the drive comes through the right side footwell so control pedals have to be on the left
Easter #53859 06/12/10 07:54 PM
Does that mean they will all be "left-hookers" If so - very strange confused2
moggieplus4 #53860 06/12/10 08:05 PM
yes - as far as I am aware, but not really a big deal in a narrow open car, and when you tour the back roads of rural France you will be sitting in the plum seat
Easter #53877 07/12/10 07:18 AM
With no weather protection I don't see a large number being used for touring...
Hmmm, wonder if I could find one to borrow for a potential end to end run next year? Would be a bit quicker than my 4/4! grin2
Cheers,
le Asbo du Bling
le Asbo du Bling
[quote=A11OGE]I believe the main market for the 3 wheeler is expected to be the USA, hence HD engine + left hand drive etc. Mind you there has been great interest in the UK. uk
Gents are you sure about this, as the engine is a V the output shaft should be centrally located. See below. This will then connect the the gearbox. If the shaft is offset then the gearbox will also be offset which does not appear to case in the pictures on the MMC site.
Am I missing something? confused
Slowly going green
asbojohn #53883 07/12/10 09:05 AM
the driveshaft has to come on one side of the rear wheel, so that is creating the disymetric (is that correct?!) chassis.
Page 1 of 4 1 2 3 4
