0 members (),
252
106
Topics49,847
Posts837,389
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
This is the beast I use
Craig Jezz
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
Craig, I know when I am beaten. Yours is bigger than mine...
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
This is the beast I use  And do you take that on tour with you ?
Bob
Posts: 6,957 Likes: 116
Posts: 6,957 Likes: 116 |
Stewart...off your meds ?!!!
hee hee I think he's ON some meds!
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
hee hee I think he's ON some meds! Suppositories inserted by greasegun?
Posts: 22,358 Likes: 353
Posts: 22,358 Likes: 353 |
Don't use that on the propshaft Craig it will very likely blow the dust seals!
This is the beast I use  And do you take that on tour with you ? Don’t be silly it’s too big
Craig Jezz
Posts: 2,116 Likes: 68
Posts: 2,116 Likes: 68 |
Here you have one, taken from ebay: https://www.ebay.com/itm/Vintage-Wanner-Grease-Gun-Swiss-Made-Classic-Car-Tool-Kit-VW-Etc-Works-Fine/382597366113?hash=item5914948161:g:QYAAAOSwo0VboQtv:rk:8:pf:0
Thank you Robbie! Just bought one!
Posts: 504 Likes: 2
Be my guest. And here is how to make gaiters: https://sites.google.com/site/morganatica/70-modifications/front-spring-gaitorsI just made for the rebounds, I think it should be enough. As for the angeled nipples, for instance this one: https://www.ebay.com/itm/Connect-31218-45-Angle-Grease-Nipple-M10-x-1-0mm-Pack-50-/282310439138?ef_id=:G:s Of course they come in 90 degrees too. Should be easy to get from any mechanical shop. A bit fiddly to change (best to loosen and almost pull off the lower part of the schock to get more workspace), but once they are in it is a real improvement. Mine are 45 degrees.
Posts: 990 |
Regarding king pin wear - the stub axle bit that goes up and down wears the pin most where it sits most of the time. The two ends of the pin don't get rubbed by the bushes so much so don't wear as much as the section that see the action. In the ideal world it would be the bushes that wear but it seems the actual pin does as well. Trouble comes when the car is jacked up and you check for wear - if the stub axle has moved away from its normal sitting position to a relatively unworn bit of kingpin the wear won't be so obvious. Ideally need checking at ride height on a play detector rig like at MOT time. I imagine a car with worn kingpins/bushes would be sloppy in the steering/handling but don't know.
I have greased mine at least every 500 miles - often more like every 250 miles from new. At 7500miles the kingpins were stripped while Wolf performance gaitors/bearings were fitted which allowed inspection of the kingpins for wear. Not knackered but some minor wear was measured - based on which Cain reckoned they would need changing by the time 20K was covered - less if I reduced my frequent nipple attentions! I reckon 20K isn't a disaster really as the job is straight-forward and can-be budgeted for - once done with hard chrome pins I guess it'll last longer too.
BHM Keith told me not to overdo the top ones - max 4-5 pumps I think he said or you risk over-filling and removing suspension travel.
2015 Morgan 4/4 (Wolf fettled) previously 2014 M3W MINI Cooper S and numerous BMC/BL relics.
