Topics49,860
Posts837,484
Posts: 1,943 |
Regarding king pin wear - the stub axle bit that goes up and down wears the pin most where it sits most of the time. The two ends of the pin don't get rubbed by the bushes so much so don't wear as much as the section that see the action. In the ideal world it would be the bushes that wear but it seems the actual pin does as well. Trouble comes when the car is jacked up and you check for wear - if the stub axle has moved away from its normal sitting position to a relatively unworn bit of kingpin the wear won't be so obvious. Ideally need checking at ride height on a play detector rig like at MOT time. I imagine a car with worn kingpins/bushes would be sloppy in the steering/handling but don't know.
I have greased mine at least every 500 miles - often more like every 250 miles from new. At 7500miles the kingpins were stripped while Wolf performance gaitors/bearings were fitted which allowed inspection of the kingpins for wear. Not knackered but some minor wear was measured - based on which Cain reckoned they would need changing by the time 20K was covered - less if I reduced my frequent nipple attentions! I reckon 20K isn't a disaster really as the job is straight-forward and can-be budgeted for - once done with hard chrome pins I guess it'll last longer too.
BHM Keith told me not to overdo the top ones - max 4-5 pumps I think he said or you risk over-filling and removing suspension travel. Do You have stainless king pins. They wear fast. If so change to Hard Chrome.
Button
Posts: 2,310 Likes: 5
Posts: 2,310 Likes: 5 |
I managed 25,000 miles on my 2014 4/4 before changing king pins..also done by Cain.
I got used to greasing every 500 miles.
It is not unknown for oe king pins to be worn at 10,000 if not well greased I am told.
Posts: 3,824 Likes: 69
Posts: 3,824 Likes: 69 |
It is not unknown for oe king pins to be worn at 10,000 if not well greased I am told. It's not at all unknown even if they've been properly greased too! (Grits teeth and grins)
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
Just got a couple of questions regarding Grease and the Wanner gun
Uh wanner wanner wanner huh!
Tell me more, tell me more Does the nozzle go very far? Tell me more, tell me more Like is it good for your car? Uh-huh uh-huh uh-huh uh-huh
A little late, but what the hell....: It's the one you should want Uh-huh-huuu it's the one you should want Uh-huh-huu It's all you need Oh, yes indeed It's the one you should want....
Robbie the Norseman 2004 V6 Roadster Sherwood green
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
A little late, but what the hell....: It's the one you should want Uh-huh-huuu it's the one you should want Uh-huh-huu It's all you need Oh, yes indeed It's the one you should want....  Very good Better late than never
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
It wasn't exactly grease lightning, was it?
1972 4/4 2 Seater
