4 members (MATTMOG, sewin, DavidR, Robbie), 520 guests, and 39 robots.
+8Rich 70
Adam12 69
John V6 53
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,508
Members9,215
Winglad
#544297 23/11/18 04:53 PM
DaveW Offline OP
I have no doubt whatsoever that this thread will be grabbed by the unworthy, and dragged through the dust of thread drift.
However I have a serious question....................
A poll of opinions..........
About electrical connections.
When I clean my battery terminals, which every conscientious owner should do occasionally, I lick the battery terminals round with Vaseline before replacing the leads. But does Vaseline conduct electricity? I doubt it does, so what's the alternative?
Then again, on chassis earth points, metal on metal, I would usually use Coppaslip. Assuming that the 'copper' content (if any) will conduct. Is it better to shine up the metal, bolt it up, and maybe dribble ACF50 over the joint???
Lets have some views please...................
DaveW #544300 23/11/18 04:59 PM
I always thought the Vaseline was put on after bolting up the terminals to keep the moisture out and stop corrosion.
Vaseline was used long before the arrival of ACF50 so I'm tempted to say clean the terminals, bolt them up then apply the ACF 50 which is designed for electrical connections and will bleed into the joint.
ACF50 actually mentions battery terminals on the packaging.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
DaveW #544302 23/11/18 05:09 PM
I use this as it's conductive.
Lithium grease aerosol
I used LM grease until it appeared they both prevent corrosion effectively.
Dow Corning
This stuff is brilliant at preventing ingress of moisture for general exposed connectors and batteries.
2009 4/4 Henrietta
1993 Connaught Green +8 prev
DaveW #544303 23/11/18 05:20 PM
I have always used CRC Copper Paste on battery terminals
2005 Roadster 3.0 S1
1960 MGA Roadster
Regards Aage
DaveW #544305 23/11/18 05:30 PM
SBM Offline
I use Dielectric Silicon Grease on exposed connections. Satnav contacts on the bike, all plug together wire terminals etc etc. I've even smeared it on rubber door seals around car doors to avoid freezing up in cold weather.
Now..about dragging the thread through the smut.. would we..? innocent
DaveW #544311 23/11/18 05:41 PM
Dave
I have used something called No Krode or No Corrode or similar product. I think it was made by Holts and came in a toothpaste type tube. It was red in colour. A quick internet search failed to find it but came up with a similar product made by Veraschem, see http://www.itwconsumer.com/versachem-products/product.cfm?id=Battery%20No%2DCorrode%20Gel%2C%20Pocket%20Pack-162
and Halfords do battery anti corrosion pads at £1 for a pair, helpfully one red, one black. Not very clear how they work.
Tony
Originally Posted By Tony Quinn
Dave
Tony
I still use the red Holts stuff, mind you the tube must be 20+ years old !
DaveW #544313 23/11/18 05:48 PM
Yes, it was Holts No-crode. It came up on a search leading to eBay, of course! There are similar products on eBay such as Durite anti corrode battery gel.
Tony
DaveW #544319 23/11/18 06:04 PM
E
E
There is a german company who sell a battery terminal grease available on ebay etc.
I have purchased some tubes of it but never used it yet.
It is called Liqui Moly Battery Clamp Terminal Grease.
Some info
Plastic compatible special grease based on lime soap. Protects battery terminals and electric contacts from corrosion and oxidation. For sure starting, bright lights and longer battery life. Prevents acid damage. Good compatibility with plastics. Prevents leakage currents and contact resistances. Designation acc DIN 51502 K2G-30. Service temperature: –30 °C to +100 °C.
https://pim.liqui-moly.de/pidoc/P000366/3139-BatteryClampGrease-18.0-en.pdf
DaveW #544320 23/11/18 06:13 PM
E
E
A UK company called Grenville also sell a battery grease.
