Topics49,871
Posts837,682
Posts: 6,958 Likes: 117
Posts: 6,958 Likes: 117 |
Same colour, but that's all I can add. Love the number plate.
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
 It's now on the correct car - the +8 V8. I have a few WMD plates - V8, V12 and W12. They were funny at the time.
+8 4.8
Posts: 6,671 Likes: 438
Posts: 6,671 Likes: 438 |
I have a few WMD plates - V8, V12 and W12. They were funny at the time. I have a group of mates, and we call ourselves the WMD club - we all sat round one evening and worked out financially we were all Worth More Dead than alive
Posts: 11,533 Likes: 318
Posts: 11,533 Likes: 318 |
Cibie Oscars, Luvly. Just discovered they do a Main/Dip version. I wonder if that's legal to use on dipped beam?
I used to have them on a 1303S Beetle, they were called Bi-Oscars back then and there were two model. Main/Dip Main/Fog https://www.holden.co.uk/displayproduct.asp?pCode=010.403
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Craig, I have seen somewhere - don't know if it was here or elsewhere, that an italian Morgan specialist does a badge bar specifically for mounting spot/fog lights. Be buggered if I can find it now though. I think a set of 'period' looking spots would look great on the front of my 4/4 but share your reservations about drilling into the bodywork. Try the Italian dealer, Borgi for a spot lamp solution. I just saw this. The photos that I took just after I had the Borghi badge bar and driving lights fitted are in this thread. The bar is anchored to the overiders and the cabling is hidden behind the overiders. I'll Post them here anyway.    PS. There is also a thread on the same subject here.
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
Looks like a win, win with that setup Peter. You brace the flimsily mounted overriders and in so doing provide a braced mount for the spot lamps located each side of grill
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
It does seem clever. Must resist the urge to splurge.
Posts: 11,616 Likes: 43
Posts: 11,616 Likes: 43 |
Definitely looks the business
Nicer then having to drill the ali and nicer looking than the spot brackets
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
Looks nicely engineered, and the classic Lucas lamps look great
Looks like a win, win with that setup Peter. You brace the flimsily mounted overriders and in so doing provide a braced mount for the spot lamps located each side of grill That was one of the things that impressed me. The whole setup becomes quite rigid and stable, overriders included. It does require two holes drilled in the overriders but once fitted you are unlikely to want to remove it again..
