4 members (vbalddave, John V6, sprinty, Saxonian), 244 guests, and 83 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
#555783 25/01/19 02:12 AM
alan m Offline OP
Hi the bottom of the headlight mount has broken where the bolt goes through,
Any suggestions on a replacement,also how is that grub screw that hol dis the bolt
removed ?
Thanks
Alan
Hi Alan ,
re removing the grub screw - my car failed its MOT on headlight alignment , and to lower them I needed to loosen this grub screw. Mine was rusted solid, so in the end I had to use a screw extractor , drill and tap to next size up , and to use stainless bolts with a head you can get hold of instead !
Its now on my winter check list to remove and grease these screws.
Good luck
Graham
The grub screw is M5 use a good quality or new allen/hex key or you will risk rounding over the edges of the grub screw and then will have to drill them out I replaced mine with stainless steel.
I think these are the head light units price per pair
https://www.s-v-c.co.uk/product/7--free-standing-black/
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
0
Looks like a few additional 'OE' parts can be sourced here as well: pedal box, fuel cap, flag badges, etc.
'17 M3W:
'08 Ural Gear-Up
alan m Offline OP
Thanks for that
Alan
I had this trouble too. SVC were good enough to supply me with just one headlamp shell only.
I seem to remember that the piece that pulls down onto the neck of the shell had a sharp edge that made the contact. I blended this in.
Just a message to thank you for the address. Just order the shells at SVC. There were super fast! Thanks to Peter from SVC.
I have the same problem for the left one. The "holding slot" (at the other side of the screw) is broken at the other one... Time to change both.
I had the same issues and bought a pair of shells ex USA
Diets 7in units. The threaded fitting is smaller in diameter which makes getting wiring in a little more difficult but the means of securing the threaded part is far superior.
Cost effective even with the freight charges
