9 members (Pittsartist, asbojohn, hugo, Clipper, DaveW, RedThree, Ncik P, Winigo, Image),
215
64
Topics49,859
Posts837,507
Posts: 23 |
Hi the bottom of the headlight mount has broken where the bolt goes through, Any suggestions on a replacement,also how is that grub screw that hol dis the bolt removed ? Thanks Alan
Posts: 1,562 |
Hi Alan ,
re removing the grub screw - my car failed its MOT on headlight alignment , and to lower them I needed to loosen this grub screw. Mine was rusted solid, so in the end I had to use a screw extractor , drill and tap to next size up , and to use stainless bolts with a head you can get hold of instead ! Its now on my winter check list to remove and grease these screws.
Good luck Graham
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
The grub screw is M5 use a good quality or new allen/hex key or you will risk rounding over the edges of the grub screw and then will have to drill them out I replaced mine with stainless steel. I think these are the head light units price per pair https://www.s-v-c.co.uk/product/7--free-standing-black/
Posts: 265 |
The grub screw is M5 use a good quality or new allen/hex key or you will risk rounding over the edges of the grub screw and then will have to drill them out I replaced mine with stainless steel. I think these are the head light units price per pair https://www.s-v-c.co.uk/product/7--free-standing-black/ Looks like a few additional 'OE' parts can be sourced here as well: pedal box, fuel cap, flag badges, etc.
'17 M3W: '08 Ural Gear-Up
Posts: 23 |
Posts: 64 |
I had this trouble too. SVC were good enough to supply me with just one headlamp shell only.
I seem to remember that the piece that pulls down onto the neck of the shell had a sharp edge that made the contact. I blended this in.
Posts: 12 |
Just a message to thank you for the address. Just order the shells at SVC. There were super fast! Thanks to Peter from SVC.
I have the same problem for the left one. The "holding slot" (at the other side of the screw) is broken at the other one... Time to change both.
Posts: 398 Likes: 1
Posts: 398 Likes: 1 |
I had the same issues and bought a pair of shells ex USA Diets 7in units. The threaded fitting is smaller in diameter which makes getting wiring in a little more difficult but the means of securing the threaded part is far superior. Cost effective even with the freight charges
