1 members (BertL),
333
Topics49,844
Posts837,360
Posts: 57 Likes: 1
Posts: 57 Likes: 1 |
I've got a 2014 Plus 4. I wanted to just confirm the jacking point at the back (front sorted). To be honest the photos in the handbook are not very useful. I've searched posts on here but non look exactly like my car. I've marked what i think is the rear cross member in the photo. Note I've not posted many photos in here so I'm hoping it can be seen by you people. https://www.dropbox.com/s/z2blw4e0awfujrn/Morgan%20Rear%20marked.jpg?dl=0So, couple of questions. 1. Can you see the photo? - that would be a good start! 2. Is that the cross member marked in red. I plan to get a piece of timber - reasonable length and width to spread the load. Any comments and/or advice appreciated.
Posts: 22,357 Likes: 353
Posts: 22,357 Likes: 353 |
Yes I can see it. Yes that's the crossmember. Fit the timber to the left of those three protruding bolts, I use them as locaters!
Posts: 305 |
That is the point I use .I have 3 hockey pucks a length of timber with a centre line . Used this for past 4 years with no problems.
Jimmy 2015 4/4 Sport Green 2018 VW Tiguan 1969 Morris Minor Traveller 1960 Morris Minor Saloon
Posts: 57 Likes: 1
DaveW. Thanks for the quick reply. I was thinking of a timber just the width of the exposed cross member (red marked area) and not putting any pressure on the area where the rear valance goes under the back which has the 3 screws.
How far back behind edge of the valance does the cross member actually go?
Thanks again.
P.S. are you the author of the buying and maintaining modern Morgans? If so got it and excellent book.
Thanks again.
P.S. are you the author of the buying and maintaining modern Morgans? If so got it and excellent book. Yes that's me.......... Glad to hear you like it! My rear beam is full width. The plastic overlays the crossmember so if you keep the beam touching those three small bolts it will be fine. My beam has a rubber strip to prevent slippage.
Posts: 6,956 Likes: 116
Posts: 6,956 Likes: 116 |
My rear beam is full width. No comment.
Posts: 1,912 Likes: 93
Posts: 1,912 Likes: 93 |
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Posts: 338 Likes: 7
Posts: 338 Likes: 7 |
Note. Before proceeding, lay down either Axminster or Wilton carpet for a more pleasureable experience!
'34 Family 4 '70 +8 '03 Hummer H2
Posts: 1,575 Likes: 55
Posts: 1,575 Likes: 55 |
Note. Before proceeding, lay down either Axminster or Wilton carpet for a more pleasureable experience! Be aware that Axminster carpet quality went downhill and I believe they went under. Back up now but I don’t know about the quality. My garage floor is lined with offcuts.
Morgan Plus 4 Royal Enfield Classic 350 Brompton M6L Giant TCX Advanced
