2 members (Chris Cosher, JohnHarris), 218 guests, and 36 robots.
+8Rich 86
by stumog - 26/08/26 10:24 AM
Topics49,844
Posts837,360
#557464 02/02/19 03:48 PM
I've got a 2014 Plus 4. I wanted to just confirm the jacking point at the back (front sorted). To be honest the photos in the handbook are not very useful. I've searched posts on here but non look exactly like my car.
I've marked what i think is the rear cross member in the photo. Note I've not posted many photos in here so I'm hoping it can be seen by you people.
https://www.dropbox.com/s/z2blw4e0awfujrn/Morgan%20Rear%20marked.jpg?dl=0
So, couple of questions.
1. Can you see the photo? - that would be a good start!
2. Is that the cross member marked in red. I plan to get a piece of timber - reasonable length and width to spread the load.
Any comments and/or advice appreciated.
Yes I can see it.
Yes that's the crossmember.
Fit the timber to the left of those three protruding bolts, I use them as locaters!
That is the point I use .I have 3 hockey pucks a length of timber with a centre line .
Used this for past 4 years with no problems.
Jimmy
2015 4/4 Sport Green
2018 VW Tiguan
1969 Morris Minor Traveller
1960 Morris Minor Saloon
DaveW. Thanks for the quick reply. I was thinking of a timber just the width of the exposed cross member (red marked area) and not putting any pressure on the area where the rear valance goes under the back which has the 3 screws.
How far back behind edge of the valance does the cross member actually go?
Thanks again.
P.S. are you the author of the buying and maintaining modern Morgans? If so got it and excellent book.
Thanks again.
Yes that's me..........
Glad to hear you like it!
My rear beam is full width. The plastic overlays the crossmember so if you keep the beam touching those three small bolts it will be fine.
My beam has a rubber strip to prevent slippage.
No comment.
Best Regards
Lang may yer lum reek
No comment.
grin2
I hope this helps
Craig Jezz
Note. Before proceeding, lay down either Axminster or Wilton carpet for a more pleasureable experience!
'34 Family 4
'70 +8
'03 Hummer H2
Be aware that Axminster carpet quality went downhill and I believe they went under. Back up now but I don’t know about the quality. My garage floor is lined with offcuts.
Morgan Plus 4
Royal Enfield Classic 350
Brompton M6L
Giant TCX Advanced
