0 members (),
341
83
Topics49,870
Posts837,668
Posts: 8,684 Likes: 413
Posts: 8,684 Likes: 413 |
See my post above Nick. The grease gun head needs to lock onto the nipple. If it doesn't it needs adjusting or you need a new head.
My new Wanner grease gun had this issue. Since changing the head no issues. Once locked on grease can be squirted in at almost any angle without it leaking out of the sides. Sometimes a little difficult to break head off nipple after greasing, but moving it beyond normal limit will work.
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
I’d say the gun end is too big and not going all the way on. Unscrew the nipple a bit and try again. Don’t forget to do it back up again.
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
A flexible hose between the head and body of the gun helps a lot at times like these. Since doing this I have cut down the number of issues a lot.
Also try to slide the head on from the side rather than a full frontal attack, this will help preserve its 3 "claws" which latch onto the nipple.
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
I've always had a problem clamping on to nipples
Posts: 625 |
A flexible hose and one of these makes it a breeze http://www.alemlube.com.au/wp-content/up...ion%20Sheet.pdf Plenty of other brands of this type of coupler too now
Cheers John 2011 4/4 - "Elrond" 2007 Elfin C3 Clubman - “Gimli”
Posts: 5,466 Likes: 171
Posts: 5,466 Likes: 171 |
I bought one of these and found it to be totally useless. The coupler supplied with my grease gun is far more effective once installed on a flexible pipe.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
I just ask the actress to turn to the other side!!
Posts: 465 |
I've always had a problem clamping on to nipples I wondered when someone would latch on to this!
Dark Red 4/4 80th Anniversary
Posts: 5,182 Likes: 2
Posts: 5,182 Likes: 2 |
I just ask the actress to turn to the other side!! . Are you a bishop ?
