6 members (+8Rich, teknome, James B W, Davetherave, mph, Laurens), 489 guests, and 38 robots.
John V6 83
+8Rich 68
DaveW 67
Luddite 58
9,203 Registered Users
Goggle eyed
by Roady - 19/07/25 06:16 PM
by t50 - 19/07/25 12:07 PM
Lions Tour
by OZ 4/4 - 19/07/25 11:55 AM
Morgan rebuild on Facebook
by TBM - 19/07/25 10:50 AM
by Nick B - 19/07/25 10:22 AM
Glitch
brake reaction stay fitting
by Caveman, July 15
BHM Breakfastclub 5/7/2025
by DirkM, July 13
Parrot upgrade
Parrot upgrade
by Mr Mogoo, June 19
Topics48,331
Posts812,876
Members9,203
kamo30
I took advantage of the warm weather today to grease the kingpins, only to find that the offside one was hidden behind the damper and I had to loosen it to enable the grease gun to clamp onto it. I`ve not had this problem before so I wonder if the nipple was changed at the last service for some reason. I`ll see about changing it for a differently angled one at the Resto Show.The nearside one was done in a couple of minutes. Also cleaned the inside of the wheels with WD40 whilst the wheels were off the ground.
Then I took Megan out for a blast to check everything was OK and had a great top-down run for 30+ miles around the lanes of South Derbyshire. Days like today make me realise what a great privilege it is to have the ability to climb into a Morgan on a whim and just take off into the countryside. I got behind 4 hooded youths in a Peugeot with baked bean can exhaust and at a road works traffic light they all turned round and waved at me giving the thumbs up and smiling like toddlers - There`s hope for us yet!
I have always had this problem with the off side nipple whereas the nearside is fine. I wonder why they should be so different?
110 mile run out today in beautiful sunshine to see the progress on the SS100.
Reg
I loosen the nipple off with a spanner to get access
2025 MG ZS EV aka Trigger
Try a different grease gun head or adjust your existing one. I bought a cheap new one with flex hose and have had no trouble latching on since 😆
Snap! Must be the weather for it! But my nipples behaved themselves!
+4 GDI Royal Ivory 2015
Ford Fiesta ST2
You need to get the angle of the grease gun and the nipple to match so that the nipple can get into the grease gun head.
This is different on each side on my plus 4 and I have to turn the wheel a bit further out to do the offside.
My offside nipple is also blocked off by the damper so turning the wheel slightly is the way to give clearance.
Also went for a spin today and come back and got the grease gun and my nipples behaved as well and then fitted Dave's mohair gaiters.
Ian
2019 +4 110 Anniversary Bentley Velvet Red.
I bought a nipple gripper ðŸĪŠ. Works really well.
1936 Austin Seven Ulster Replica
I'm struggling with the nipples on my prop shaft... any tips on that? It seems to partially latch but when I pump the gun the nozzle just jumps off.
