8 members (Sir Percival, Burgundymog, High Hamster, Bishmog, +8Rich, gmcn, nick w, Luddite), 287 guests, and 82 robots.
+8Rich 77
Topics49,870
Posts837,673
Rudolf
See my post above Nick. The grease gun head needs to lock onto the nipple. If it doesn't it needs adjusting or you need a new head.
My new Wanner grease gun had this issue. Since changing the head no issues. Once locked on grease can be squirted in at almost any angle without it leaking out of the sides. Sometimes a little difficult to break head off nipple after greasing, but moving it beyond normal limit will work.
I’d say the gun end is too big and not going all the way on. Unscrew the nipple a bit and try again. Don’t forget to do it back up again.
Simon
2002 4/4
2021 Audi A1 sport
A flexible hose between the head and body of the gun helps a lot at times like these. Since doing this I have cut down the number of issues a lot.
Also try to slide the head on from the side rather than a full frontal attack, this will help preserve its 3 "claws" which latch onto the nipple.
Andy G
1999 +8 , Indigo Blue.
Black Rat
Online Sad
Black Rat
I've always had a problem clamping on to nipples pantsdown
Keith
2013 narrow bodied + 4 Ruby.
A flexible hose and one of these makes it a breeze
http://www.alemlube.com.au/wp-content/up...ion%20Sheet.pdf
Plenty of other brands of this type of coupler too now
Cheers John
2011 4/4 - "Elrond"
2007 Elfin C3 Clubman - “Gimli”
I bought one of these and found it to be totally useless. The coupler supplied with my grease gun is far more effective once installed on a flexible pipe.
Costock, UK
Disco 5
I just ask the actress to turn to the other side!!
Bruce
1994 +8 (Maurice) tis no more
2013 M3W (Olga)
I wondered when someone would latch on to this! laugh2
Dark Red 4/4 80th Anniversary
Ray Offline
. Are you a bishop ?
