4 members (Rovert, yobtaf, John Winn, Bishmog), 293 guests, and 19 robots.
John V6 70
DaveW 67
+8Rich 66
9,208 Registered Users
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Morgan 3 Wheeler song
by Dutch - 21/07/25 12:31 AM
by Oskar - 20/07/25 04:13 PM
Topics48,341
Posts813,001
RedThree
Page 1 of 6 1 2 3 4 5 6
#56223 17/02/11 11:39 AM
Hi This is my first car with wire wheels.Decided to remove wheels for greasing front end.First spinner no problem but the second one I cannot budge with the piece of wood and mallet.
Is the only way the purchasing the tool off the M.G site.
Also how tight should they gone back on.
Andrew
Hello Brownbaker, first, I assume you are trying to remove the spinner in the correct direction? They are "handed" so look at the direction shown on the spinner.
I always use a Thorex 716 hammer with replacable "plastic" striking faces ( approx £15.00 in Machine Mart ) the copper one in the tool kit can damage the chrome.
As to tightness, you will need to learn that by feel, in anycase re check after a few miles.
Hope this helps.
Reg
Green & Grown Up
Green & Grown Up
Hi Andrew,
Recommend getting one of these from the MG Owners Club website. Makes life a whole lot easier for under £50
Frank coffee
AQM Offline
Couldn't one use of those hammers with copper on one side and hide/leather on the other?
I realise those hammers are more expensive than the Machine Mart version, but you wouldn't need to have replaceable striking surfaces.
Edit: Come to think of it, couldn't one sew some leather "socks" for the spinner (connected by leather or a piece of string so they don't fall off while hammering) and then hammer with just about any hammer or even a rock.
AQM #56279 18/02/11 02:37 PM
AQM, you would probably be surprised how quick the leather would let go on the edges. Also the hide on those two-sided hammers doesn't last very long if the hammer is used in anger.
"Original equipment" on my old 4/4 was a 10 lbs. copper Hammer.
In my opinion best choice is the tool from the MG site, which is also available on the website of angloparts
http://www.anglodesign.be/images_ap/Toolcatalogue_2005.pdf
Frank
1967 4/4 1500 Comp.
1935 Super Sports Barrelback
Bodger #56283 18/02/11 04:06 PM
South Wales Correspondent
Frank
The MG Toool is good- I recently bought one and have just used to take all four wheels off and then replace them- but you have to guard against it marking the spinner itself when it is used. I tried rubber but have now come up with a small square of chamois leather which I just slip over the spinner before I fit the tool.
So far as hide-headed mallets are concerned, I agree that the hide side does 'let go' but a way around this is to buy a hgood wuality hammer which has replacebale faces ( I use a 'Thor' and find it excellent)
GLLHG
GLLHG #56284 18/02/11 04:26 PM
Another vote for the MG tool -- I stuck some old bicycle tube rubber to the tool to stop it marking the spinners - perhaps Gerwyns trick of some thin chamois on the spinners would be better - Thanks G - I'll try that next time
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Robbie #56286 18/02/11 05:51 PM
If you have the octagonal spinners, the tool from MWS is just the ticket, solid brass, low cost (£14), fits in the tool tray, and can be used with a nylon or hide hammer.
http://www.mwsint.com/Shop/Details.asp?Id=KAS42
Nigel
Nigel
Nigel,
Isn't the problem here that what we are dealing with ISN'T the normal octagonal( ie non -eared) spinners When I had these, I used the MWS tool and found it excellent but once I changed to spinners with ears, the MWS became redundant?
Cheers.
GLLHG
GLLHG #56320 19/02/11 11:26 AM
I use a rubber mallet that has metal shot inside of the head. Purchased from Halfords and cannot damage the spinner or the wheel rim if you make a mistake
1997 Plus 4, Metalic Blue.
2000 Toyota Yaris. (The Tardis)
