0 members (),
282
44
Posts837,276
Posts: 288 |
More brain pickin.....no g. AnyTM ers out there who can tell me the amount of adjustment on the pedal box on a 2013 M3W. I am an average 5ft 9inches .......will it accommodate me .
Stingmog
Posts: 1,370 Likes: 11
Posts: 1,370 Likes: 11 |
It will work for you. The right hand drive models have more travel room on the pedal box as it is asymmetric. It is fully adjustable on the right hand side but limited on the left.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Yes, you are probably the ideal size for the M3W! Even so, you will probably need the pedals to be positioned at their furthest point forward.
Andy
Posts: 288 |
Thanks Michael. Happy days
Stingmog
Posts: 288 |
Yes, you are probably the ideal size for the M3W! Even so, you will probably need the pedals to be positioned at their furthest point forward. Yes, you are probably the ideal size for the M3W! Even so, you will probably need the pedals to be positioned at their furthest point forward. Thanks Bunny
Stingmog
Posts: 557 |
5’11” here, no issues, also fitted a steering wheel spacer, which helps a lot!
Posts: 288 |
I didn’t know about a wheel spacer. Thanks from across the pond.
Stingmog
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Do short people need the spacer? 5’6” here and short legs mean I fit into thing but cannot reach a damn thing!
Posts: 365 |
I have the same spacer. They work perfectly.
The easiest way to check if you want it is to unlock your steering wheel and pull it towards you the half inch or so of travel. Of course don't do this while you are driving. What I would say it strangely enough gives you more space even though the steering wheel is closer to you. To me it makes it a little easier to get in and out.
2017 M3W Sport Green
