1 members (Ian Wegg),
360
47
Topics49,841
Posts837,324
Posts: 288 |
More TM ers brain pickin..... no g. I need to Jack the rear end and relieve the pressure on the springs to clean and lube, as I guess this is the cause of the rear end squeak !... So where is the best point to use on the chassis to do this ,Cus if I jack under the diff the leafs will still be under load.
Stingmog
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
My advice would be to buy yourself some motorcycle chain lube/wax. (Castrol or Halfords own) Brilliant stuff for use on the leaf springs.
I use a 2 tonne trolley jack, with pads, on the axle and always use axle stands (and wooden blocks) before crawling underneath. Other TMers will, I’m sure, suggest alternative jacking methods.
Bud 4/4 "Stanley"
Posts: 27,804 Likes: 749
Posts: 27,804 Likes: 749 |
Posts: 1,799 Likes: 4
Posts: 1,799 Likes: 4 |
As you say, you can't jack under the axle because that won't relieve the load on the springs.
However I would never jack on the axle. I always use the rear crossmember with a wooden pad to protect it.
Newer cars have the rear valance partly covering the crossmember but I believe there is still room.
Then put prop stands, again with pads, at the outer edges of the crossmember and lower the jack onto them.
I use very heavy duty prop stands with a bigger base area and then move the jack out for easy access.
Bob
Posts: 305 |
You can also get good access from above by taking the tool tray out .This enables you to oil the handbrake cables at the same time .
Jimmy 2015 4/4 Sport Green 2018 VW Tiguan 1969 Morris Minor Traveller 1960 Morris Minor Saloon
Posts: 288 |
Top answers. Thanks everybody. Iv ordered some Wurth chain cleaner and dry Lube. I will try the tool tray removal method before jacking. Might be simpler.
Stingmog
Doing it from underneath also allows you to give things a good check up and remember if you only use the tool tray access method, you're not unloading the springs.
Nothing beats lying on your back with dirty hands.
Bob
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
Also, Take out spare wheel to give closer access to far ends and shackle pins.
I use bike chain lube every 24 months or if it gets squeaky. I take out the spare & the tool tray. It works for me.
Posts: 8,667 Likes: 489
Posts: 8,667 Likes: 489 |
SteveH, when you buy your chain lube just check it says 'safe with O rings' that way it's safe to give the rubbers in the shackles a good soaking too, they are often the source of the squeak
