8 members (MartinB60, RubyMog95, Calypso Red, RedThree, chanteclair, RichardV6, Guern, TBM), 347 guests, and 91 robots.
Topics49,847
Posts837,389
JFV Offline OP
did somebody have knowledge how to change the standart silencer with the sport silencer on a 4/4 from 2009. I bought one and I don't know if I have to remove the hole exhaust or only rear the part? I have a strait one not with side pipe.
thank for helping me
JF
You need to undo the clamp just behind the cat. It’s easier to undo the clamp at the rear of the silencer too, undo the fittings to the tailpipe section and then slide that back from the silencer to allow the silencer to be pulled off the front mounting. Some twisting of the silencer and pipes will probably be required to release them!
It’s quite a straightforward job and I’d replace the support bobbins at the same time as they may have deteriorated.
1936 Austin Seven Ulster Replica
JFV Offline OP
Thank you very much John for your professional explanations. I will do it this weekend with a friend or one of my son! I hope the support bobbins are still ok but you are right you never know after 9 years!
Greatings from Switzerland
J-F
If the rubber bobbins need replacing, traditional Mini ones are the correct size.
JFV,
I changed the standard system on my Plus 4 to a Librands system and found that I needed larger "U" clamps and a new silencer to cat clamp. Do have some exhaust paste to hand as well.
Good luck!!
Reg
