0 members (),
295
92
Topics49,867
Posts837,614
Posts: 365 |
By the way changed the oil with redline and threw in tufoil and not convinced it made a significant difference though it might have. Mine is pretty quiet except at 70mph ish. At 70mph I get a healthy howl. I do my best to Avoid the howl.
2017 M3W Sport Green
Posts: 1,544 Likes: 1
Posts: 1,544 Likes: 1 |
Dynomatted outside of seat belt box just in front of rear wheel👍And all of the underside of prop shaft cover and gearbox cover👍👍
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
I changed the BB oil with the new Redline (no additives added), managed to get out yesterday for a good run before our 12 inches of snow today. The box still has a howl especially at 50 mph but not as piercing as before.
Posts: 365 |
I changed the BB oil with the new Redline (no additives added), managed to get out yesterday for a good run before our 12 inches of snow today. The box still has a howl especially at 50 mph but not as piercing as before. After driving mine a good bit more I would agree that the sound is definitely muted and better in general but if you have a howl before you will have a howl after I suspect.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I think Emil has run a temp gauge off his bevel box. I wonder what temps he finds it runs? I installed Emil's temp sender in the bevel box and got a maximum of 210f when climbing a 5500ft mountain with passenger on board. Changing oil to 75-140W Royal Purple (it has additives in it as well) changed the noise a little but nothing significant. Using Emil's remote oil fill tube and measuring how much you put into the BB (300ml) sure makes the drain and recharge much easier. MMC sure makes getting to that drain and fill location a difficult job, especially doing it for every oil change of engine oil. Emil made it a bit more simple.
Posts: 557 |
Just fitted a bevel box remote fill kit from MorganCustom.net and filled the bevel box with 700ml of Redline Shockproof - no noise whatsoever over 120+ miles!
Posts: 2,360 Likes: 2
Posts: 2,360 Likes: 2 |
Maxi 450 ml Classic ep 140 is enough Redline is 240 Cross fingers
Posts: 557 |
Maxi 450 ml Classic ep 140 is enough Redline is 240 Cross fingers The kit consists of an AN fitting, which you screw into the BB vent plug, and then a large clear tube which snakes to the top. Basically this allows you to add up to 850ml and still have a vent for pressure relief. I do not envision any negative effects from that? ![[Linked Image]](https://www.tm-img.com/images/2020/01/26/3E3C71EA-5926-4F9E-8588-1419BC84387E.jpg)
Ho Sorry But it seems to be too viscosity 240 I try one Time And wasnt good for me
