6 members (John V6, IcePack, Chris Cosher, High Hamster, Fox Terrier, Sir Percival), 417 guests, and 40 robots.
+8Rich 70
Adam12 69
John V6 53
9,215 Registered Users
Folding Reclining Seat Knob
Goodwood Speedmog 2d august
by Nick55 - 01/08/25 09:09 PM
Walnut Dashboard
by +8Rich - 01/08/25 06:24 PM
SORN
New
Morgan plus Four 2025
by Jérôme, August 2
Pedal mod
Pedal mod
by RibbleAdventures, July 31
4/4 80 Anniversary Rex_Tulips
by Rex_tulips, July 31
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
Topics48,375
Posts813,508
Members9,215
Winglad
#572281 16/04/19 03:26 PM
TBM Offline OP
I'm going to attempt to fit a smiths clock to my dash tomorrow, in the space to the right of the rev counter.
Have a brand new 52mm hole saw - the plan is to measure out the hole, and remove a circle of vinyl from the dash slightly larger than the hole before I start drilling - it will be covered by the bezel.
Any tips or hints before I take the plunge?
Don't do it !!!!! ( only winding you up )
Reg
Good luck. I would cover the area with masking tape so the drill doesn't slip.
2025 MG ZS EV aka Trigger
My secret with hole saws, is to drill the pilot hole first with a separate drill, and most important use REVERSE for the first few revolutions to drill the first 2 or 3mm depth with the hole saw
TBM Offline OP
Great tips, thank you!
CBY Offline
You can try to use this kind of compass to cut the vinyl:
https://www.amazon.co.uk/Olfa-Compass-Cutter-cutting-circles/dp/B000BK7NWC
Regards
2005 PLUS 4
excellent advice which does work; I would also second the use of masking tape over the dash.
I know it's a spanking new hole saw but I would also be inclined to do a test cut on some scrap and make sure the saw is true to size....
James
Mercedes EQC 400 AMG
Smart Brabus Convertible
Honda Monkey Z125
Do not cut the vinyl larger!!!! The width of the bezel is not so much more that the diameter of the hole that you will need.
Peter is dead right , put some cuts in vinyl outwards and peel back before drilling then fold it inwards through the hole after filing the hole to a snug fit (including the thickness of vinyl) this will avoid any unsightly gaps showing when you are exposed to big temperature changes.
99 plus 8 indigo
I agree with Peter, when I cut a hole in my dash I first cut the hole in a piece of plywood and then inserted the gauge to check on hole size and bezel fit. Once satisfied I went for the real thing.
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
