8 members (ChrisConvertible, JohnHarris, Stephen888, JMcL, SEG, Alan Patterson, TBM, stumog),
207
54
Topics49,871
Posts837,676
Posts: 6,671 Likes: 438
Posts: 6,671 Likes: 438 |
I'm going to attempt to fit a smiths clock to my dash tomorrow, in the space to the right of the rev counter.
Have a brand new 52mm hole saw - the plan is to measure out the hole, and remove a circle of vinyl from the dash slightly larger than the hole before I start drilling - it will be covered by the bezel.
Any tips or hints before I take the plunge?
Posts: 5,549 Likes: 67
Posts: 5,549 Likes: 67 |
Don't do it !!!!! ( only winding you up )
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
Good luck. I would cover the area with masking tape so the drill doesn't slip.
Posts: 8,684 Likes: 493
Posts: 8,684 Likes: 493 |
My secret with hole saws, is to drill the pilot hole first with a separate drill, and most important use REVERSE for the first few revolutions to drill the first 2 or 3mm depth with the hole saw
Posts: 375 |
Regards 2005 PLUS 4
Posts: 1,767 Likes: 21
Posts: 1,767 Likes: 21 |
My secret with hole saws, is to drill the pilot hole first with a separate drill, and most important use REVERSE for the first few revolutions to drill the first 2 or 3mm depth with the hole saw excellent advice which does work; I would also second the use of masking tape over the dash. I know it's a spanking new hole saw but I would also be inclined to do a test cut on some scrap and make sure the saw is true to size.... James
Aero8 , Series 1 - Boston Green RR Evoque P300E Autobiography Smart Brabus Convertible Monkey Z125
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Do not cut the vinyl larger!!!! The width of the bezel is not so much more that the diameter of the hole that you will need.
Posts: 1,633 Likes: 62
Posts: 1,633 Likes: 62 |
Peter is dead right , put some cuts in vinyl outwards and peel back before drilling then fold it inwards through the hole after filing the hole to a snug fit (including the thickness of vinyl) this will avoid any unsightly gaps showing when you are exposed to big temperature changes.
99 plus 8 indigo
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
I agree with Peter, when I cut a hole in my dash I first cut the hole in a piece of plywood and then inserted the gauge to check on hole size and bezel fit. Once satisfied I went for the real thing.
