7 members (Bishmog, atalante83, Tweed19er, 1560, Luddite, dezzn, DavidR), 338 guests, and 34 robots.
John V6 69
DaveW 65
+8Rich 62
Dufty, Anted4, 4199, GOFFO1965, Joske Vermeule
9,212 Registered Users
195/60 R15 for 2018 Plus4
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,348
Posts813,089
Members9,212
aeroed, DJC, James Mc, JimWhin
Page 2 of 5 1 2 3 4 5
check the heat guard bolts are tight, i had a rattle, that cured when nipped up
M3W 2014 Red (with White Stripe)
g56 stage 1
I have also some rattling noise from my right pipe. Can’t trace it where it comes from. I suspect something inside. In that case I probably need to live with that.
www.m3w-jungfrau-treffen.com
Do you all, with G56 pipes, have a rattle?
How strange.
John.
Also with me a rattle with right pipe. Extreme with cold engine.
In the video https://www.youtube.com/watch?v=NH6OCVNsO3I at 1 min good to hear.
Andy
2015 M3W G56 Stage1 + ECU
2013 Morgan +8
2008 Dodge Challanger
So I make that 5 to date with the same presentation.
What I would be interested to know is :
Is there anyone with G56 pipes without a rattle ?
Also if anyone did have a rattle , and it has now gone/reduced having put some miles on ?
Thanks
Thanks for Posting the video Andy, that is quite the rattle!
I have the 56 stage 1 and have always thought they sounded great. Over 5K now and luckily I have never noticed a rattle but will now listen hard. Although if they sounded like the video I would have noticed by now. Whenever I have taken the car back to the factory it's the mountings that always get a comment and criticism. I don't think they like the extra weight, that the car is not designed to take, at those points.
M3W, Bentley Continental 6.0 Flying Spur, MGB BGT. Beetle Conv, Merc Est, Renault Cleo.
+1 for me.
+1 for me.
For sure it’s not the heat shield which I checked thoroughly. It’s looks inside and started after many thousands miles. But it’s hard to check yourself when driving a left hand car. And ......the noise it’s not always there !
But thats typical Morgan 😜
I think the rattle that is in the video is not the exhaust but the Centa compensator as the car is pulling away at very low revs and it tends to do that. I also have the minor popping "rattle" at idle on my RH G56 exhaust, it seems to be common to them all. It's been the same for over 12,000 miles and I don't really notice it now. The first early G56 system I had definitely had something loose in there as there was a rattle if you slapped the box, the replacements don't. G56's explanation could be correct but I don't know why just the RH side.
I had one heat shield screw that had bottomed out and appeared to be tight when it wasn't. Filed a bit off the thread and Loctited them all in.
