3 members (Cat302, number thirteen, TrickieDickie), 341 guests, and 103 robots.
Topics49,847
Posts837,391
DazMog, The Impaler, tlchzj79
#577083 19/05/19 06:26 AM
Keith H Offline OP
Hi there. I am Buying a Garmin satnav and am looking for advice as to the
Best method for installing into the three wheeler. Is there a specific mount you have found works ?
Many thanks
Keith
Garmin Friction Mount
The base comes with a sheet of thin plastic that you peel off before installing. It is quit sticky and will keep it from moving. I like it as it puts the unit in the shade where one can actually see what's on the screen. I cram it as far forward on the center console as I can. In the bright sun, wearing any type of Polaroid sun glasses can be hopeless. Having it on the console acts as a cushion so that when the car is vibrating at idle or low revs you can actually read it!
remove one allen bolt and replace with a small ram mount ball, attach sat nav that way
good for other half to hang hand bag on when no sat nav!
M3W 2014 Red (with White Stripe)
g56 stage 1
Q
Q
I ordered the ram mount x grip short with a tough ball m6-1 6mm for my i phone xs. install is going to be on the lower bolt of the silver plate to the right of the rpm.
Keith H Offline OP
Thanks all for the replies. Much appreciated .
Keith
Getting ready for Grindelwald, Keith? Worth practising your u-turns for when Red Leader’s Garmin goes rogue! 😊
That's all part of the planned fun innocent
Red Leader drive
Indeed. It wouldn’t be a proper Grindelwald trip without the occasional u-turn! 😊
U-turns otherwise now known in our family as “doing a Chris” ...... 😊
