1 members (Saxonian), 287 guests, and 76 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
Page 5 of 8 1 2 3 4 5 6 7 8
Originally Posted by Uther
Absolutely brilliant work, nice to see you are using safety retaining washers on the Rose joints too ( pretty sure I see them in a least a couple of photos) it’s a small but significant detail that many people miss when doing work like this. Attention details like those door hinges and the isolator key are the mark of a real craftsman too.
You are going to have one hell of a good car when you are finished. Well done 👍🏻
Thanks ! All rosejoint are sealed and nordlock washers or kingpins är used to lock them off.
Work continiuos with bodypanel fitment and adjustment, since the car is a bit wider than a stock Morgan the bonnet had to be widend.
Tge bonnet is also a bit shorter due to the fact that i changed the rake of it , had to make new fasteners/hinges.
Started to make my own dashpanel from a piece of MDF. Most of the cars functions (speedo, rev. counter , oil pressure , water temp etc etc) will be connected to the dash but I still wanted a Classic look so I restored a set of Smith gauges I had from a old Jaguar with new chrome bezels and a good Clean (2 done and 1 to go). I also made a panel where the glovebox usally is located , the panel got some attention in the mill to create the classic look, behind it the complete fuse/relaybox is located,'
I am deeply impressed by the work an craftsmanship on display here, wow! I am looking forward to see pictures of the finished product and a write up on how it drives!
Success!
2025 Plus Six - 1909
2009 Roadster
1983 4/4 4str
Formerly known as Aldermog
Magnificent workmanship.
It looks as if it will be about the same with as the Aero+8, the car is 1.26m wide at the door hinges.
The louvres are 5cm from the hinge bar, the additional width is between the bonnet curve and the outside of the louvres.
As has been said, if you can do this why hasn't anyone else done this in the last 30 years???
Success!
Thanks, will do!
I Think it will be quite a bit smaller than the Aero 8 , at least lower.
It has been allot of work , spending 4-5 nights a week (3-5 hours / night) during the last 22 months.
/Carl
So , more or less in present time now:
Back from paint and during re-assembly
image share
image share
image share
Intake with backplate , pipercross filter will go on top of this:
image share
Heatshields on exhaust:
image share
image share
Great colour and fantastic work, you must be really pleased with the outcome.
The "pods" for the rear lights was on back-order so I fabrikated my own, will be painted.
image share
image share
Driver Aeroscreen fitted :
image share
More or less complete and ready for registration (hopefully next week)
image share
Had to change to a differnt Wheel set-up , the silver ones were 8" wide and simply did not fit + legislation in Sweden forced me to choose a 7" wide rim insted.
image share
Yes , I like it , industrial grey , I belive it is very close to Morgan sports grey (?)
