4 members (Graham, G4FUJ, Sir Percival, Hamwich, Ritchie B), 173 guests, and 38 robots.
+8Rich 91
by stumog - 26/08/26 10:24 AM
Topics49,843
Posts837,340
Christoph
Page 7 of 20 1 2 5 6 7 8 9 19 20
Was able to remove the gas tank without removing the swingarm:
Wow, that looks brand new KankeL. I wish I could keep mine half as clean as that!
Andy
What is the shredded red stuff around the pinion gear on the drive belt?
Bristles from the brush.
They seem so out of place because everything else is so squeaky clean.
It’s my high-tech trunk prop!
Well it apparently works just fine. Your three wheeler is so clean that it should be on a revolving table in your home!
Thank you, I had given it a wash before I started disassembling the rear-end :-)
Adding myself to the list of car owners with failed tanks and/or tank brackets frown
DocNik
Chris99
MarkH
RedThree
Dolph
RicHardy
ArchieWetLeg
Bunny
Planenut
KankeL
PaulV
Also, my tank strap tensioners were cracked (an m8 stud welded to a seatbelt bracket) and I think that had caused the belts to get loose and the crack to develop. Check yours.
