2 members (Zach, BLUE+4),
332
Topics49,843
Posts837,335
Posts: 557 |
Was able to remove the gas tank without removing the swingarm: ![[Linked Image]](https://www.tm-img.com/images/2019/07/20/1FFF1E6C-FD83-45DC-9C57-6BEDF0B3FDC4.jpg)
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Was able to remove the gas tank without removing the swingarm: ![[Linked Image]](https://www.tm-img.com/images/2019/07/20/1FFF1E6C-FD83-45DC-9C57-6BEDF0B3FDC4.jpg) Wow, that looks brand new KankeL. I wish I could keep mine half as clean as that!
Andy
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
What is the shredded red stuff around the pinion gear on the drive belt?
Posts: 902 |
They seem so out of place because everything else is so squeaky clean.
Posts: 557 |
It’s my high-tech trunk prop!
Well it apparently works just fine. Your three wheeler is so clean that it should be on a revolving table in your home!
Posts: 557 |
Thank you, I had given it a wash before I started disassembling the rear-end :-)
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Adding myself to the list of car owners with failed tanks and/or tank brackets  DocNik Chris99 MarkH RedThree Dolph RicHardy ArchieWetLeg Bunny Planenut KankeL PaulV
Posts: 557 |
Also, my tank strap tensioners were cracked (an m8 stud welded to a seatbelt bracket) and I think that had caused the belts to get loose and the crack to develop. Check yours.
