6 members (BobtheTrain, Strathaven, Simon, B3MOG, BLUE+4, Joske Vermeule), 252 guests, and 45 robots.
+8Rich 82
Topics49,859
Posts837,498
Jonny72
#595712 18/09/19 10:29 PM
Starting this morning and perhaps getting slightly worse throughout the day I have what I would describe as a sticky throttle.
I noticed this morning that I appeared to have cruse control after the car continued forward at around 30mph without my foot on the accelerator. This continued when I stopped at traffic lights with the engine on a high rev idle with the clutch pedal down.
A quick blip of the accelerator tends to sort it.
I would really like to sort this out myself as I'm a long way from a Morgan Dealer. (Sheffield) Where do I start!? A bit of lubricant on a cable somewhere I presume?
The car is around a year old with roughly 2k miles. I've not done much to it other than move the pedals back a few weeks after I got it last spring.
I had the same problem. If I recall rightly, I think there was a spring involved and it had broken and needed replacing.
A frayed throttle cable maybe, or lubrication if it is actually sticking? Also a faulty idle air control motor or wheel speed sensor will hold the revs higher than normal.
Return spring on the throttle pedal.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
I've heard of throttle cables 'sticking' a couple of times recently. Does anyone lubricate the cable as part of their preventative maintenance?
Andy
I had my throttle cable touching the cylinder and melted just enough to get the throttle to stick from time to time.....it was quite interesting to drive sometimes until I found the problem..:-)
Bear in mind that if the throttle is stuck slightly open then the car won't start.
Red Leader drive
That is an interesting and useful fact.
Birchenall, if you want some help or an extra pair of hands, give me a shout (via PM) as I'm Mog tinkering this weekend & located in the 'Peoples Republic of South Yorks'
Thanks, Rog. Yes, that was it!
