1 members (+8Rich),
360
50
Topics49,860
Posts837,485
Posts: 8 |
Starting this morning and perhaps getting slightly worse throughout the day I have what I would describe as a sticky throttle.
I noticed this morning that I appeared to have cruse control after the car continued forward at around 30mph without my foot on the accelerator. This continued when I stopped at traffic lights with the engine on a high rev idle with the clutch pedal down.
A quick blip of the accelerator tends to sort it.
I would really like to sort this out myself as I'm a long way from a Morgan Dealer. (Sheffield) Where do I start!? A bit of lubricant on a cable somewhere I presume?
The car is around a year old with roughly 2k miles. I've not done much to it other than move the pedals back a few weeks after I got it last spring.
Posts: 637 |
I had the same problem. If I recall rightly, I think there was a spring involved and it had broken and needed replacing.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
A frayed throttle cable maybe, or lubrication if it is actually sticking? Also a faulty idle air control motor or wheel speed sensor will hold the revs higher than normal.
Posts: 1,625 Likes: 25
Posts: 1,625 Likes: 25 |
I had the same problem. If I recall rightly, I think there was a spring involved and it had broken and needed replacing. Return spring on the throttle pedal.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
I've heard of throttle cables 'sticking' a couple of times recently. Does anyone lubricate the cable as part of their preventative maintenance?
Andy
Posts: 107 |
I had my throttle cable touching the cylinder and melted just enough to get the throttle to stick from time to time.....it was quite interesting to drive sometimes until I found the problem..:-)
Posts: 3,732 Likes: 79
Posts: 3,732 Likes: 79 |
Bear in mind that if the throttle is stuck slightly open then the car won't start.
Red Leader
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Bear in mind that if the throttle is stuck slightly open then the car won't start. That is an interesting and useful fact.
Posts: 8,675 Likes: 491
Posts: 8,675 Likes: 491 |
The car is around a year old with roughly 2k miles. I've not done much to it other than move the pedals back a few weeks after I got it last spring. Birchenall, if you want some help or an extra pair of hands, give me a shout (via PM) as I'm Mog tinkering this weekend & located in the 'Peoples Republic of South Yorks'
Posts: 637 |
I had the same problem. If I recall rightly, I think there was a spring involved and it had broken and needed replacing. Return spring on the throttle pedal. Thanks, Rog. Yes, that was it!
